Lathe cross-slide Identification help
Brad54
Got this as a spare part with a Myford 7 lathe I picked up several years ago.
It's definitely not for the Myford 7; Can anybody help me ID it? I'd like to make it go away, but "For Sale: Random lathe cross-slide" probably won't do well!
rsanter
visalia ca
I think that is an add on cross slide for a wood lathe so you can do light metal work on it.
matt_i
SE Michigan
With those ball-cranks its +/- 100 yo if it was part of a metal turning lathe.
But as you can see it has none of the provisions for Vee and Flat ways and missing the power feed/leadscrew parts that would be part of a thread-cutting machine.
One of the first advances I see is that the graduated dials got really large in diameter and read in "diameter" instead of reading in "radius".
macgee
Sepulveda Pass, CA
I was going to say a Sheldon lathe but the underneath is not even close.
That casting does not look very robust nor typical of a metal lathe cross-slide (that I'm aware of).
