Sturdy shop towel holder?
5-0stank
PA
That blue point one looks just like harbor freight one.
I have the harbor freight one, and its great for 7.99 or whatever it is. Magnets are plenty strong.
Stuart in MN
Minneapolis
I made one out of galvanized pipe. Attached a flange to the side of a wood shelf unit, screwed a 12"piece of pipe into it,slipped on a rollof towels then added an elbow and a cap to keep it from sliding off. Cheap and sturday as can be.
Coach
This is exactly what I was going to recommend.
e-tek
Saskatoon, SK
Quote:
Coach
Yes - you MUST make one for your shop. Mine is a made from the handle of a window squeegie.
Ign
Butte Peak ND
I use an axleshaft run thru a couple radius arm brackets.
Ilikeike
Northern Ca.
I’m late to this party but real simple an nice 3/4” copper wall mounted to a 3/4” “floor” pipe flange. Looks good real simple , design your own angle for wall or under cabinet mount.
Deadsquiggles
Chesapeake, VA
I used the magnetic two piece paper towel holder from HF. I actually have them stuck to an old full handsaw blade that I screwed to a stud over my sink. It’s be there for 3 years without issue.
16again
Boynton Beach, FL.
Just bought one of these and it works well. Bought it at lowes. It's easy to change and because it can only be loaded from top (the spring loaded tabs prevent roll coming out from bottom) it the roll can't pop out when pulling on the roll for a sheet.
http://www.amazon.com/dp/B000AXG5ZQ/?tag=atomicindus08-20
3T8Va3T1g5O1zByWVytN3WKUy26FU-bri0gOwsJIho-D0wkDibdKWtNNySB-tU1W7B6UM81TUdfQrKNChtRN3r93HO4trw4uK6Awdu-D_0ft4bcI_fSzFEqLog_ZYCsX9KP4YkWmly1xpIwqHKX-YyaZLnxsXq_HroONdlU7TBInRDaXmwEnA17HSuXJtcKCuhF89BWt_lczBDDSVgkt7w7sku-EQVlq3rFgLJTue6JEDIfr6GZTX7JGycQjdg7EKaBU9B70Xq1M3clC-_3180bBEaEO_UVNOQ-O8TusNN9oyk1JxNMkKInZL7TajVMzA2-mkmC4vif9Rg
I literally just ordered this. Have one at work and haven’t been able to locate another one. Finally saw this thread and the link still works. Will be here Sunday. :rocker:
Ilikeike
Northern Ca.
Like in my post above, 3/4" copper and a floor flange.
easy peasy japanesey
I also made a double shop towel rack with two flanges.
Mgdoug3
KY
I almost went to Harbor Freight to buy a paper towel holder but decided to look at my scrap pile first. Ended up making one that seems to do just fine.
Ralf11
only plumbers should make them out of pipe
electricians should use conduit
car mechanics should use car parts
woodworkers should use only wood - cabinet grade
framing carpenters should use pine or fir
16again
Boynton Beach, FL.
thr3squared
CA
Ive got the HF Towel holder - works great got it for 5 bucks on sale !
NICE STRONG magnets that are encased in rubberized plastic (no scratch)....beats
the HELL outta buying the same thing from snap-on for 35 bucks or Griots for 20 !
Just shot mine w/ some black paint (no prep) - to match the the KRL7023 !
I've used these without any issues.
jweller
I gotta say I'd be embarrassed to show a pic of the one I built 20 years ago when I was poor as all get out and building a paper towel holder out of scrap wood was the only way I was gonna have one, but it's lasted 20 years and 3 moves, so maybe it was OK after all.
joeturbo
I have got the ones from Menards also. They also make nice air hose and electric cord hangers.
Hankoh
Northwest Ohio
Well I understand jweller not wanting to post a simple thrown together from scrap holder, but here is one I made. Nothing special but it works and did not take much time to make.
GeeTeeOhh
Eastern Washington
made a couple out of leftover 1/2" copper pipe and fittings. second one is for hunters...
Ty.
Northern Wi
I built this quite a few years ago for the boxes of rags, its also a good place to mount the gojo
Bigbird
New Hampshire
Another plug for the Harbor Freight version. Great if you have a spot to magnetize it to. Inexpensive as well.
Radio Flyer
Suburban Chicago
Yes!
I have always wanted to make one out of 2 old connecting rods, and a piece of broomstick slid through the wrist pin ends.
I just don't see connecting rods big enough anymore.
