I thought I would follow up with some tips for anyone replacing a recirculation actuator in a Jeep Wrangler.
First I hate interior work but I’ve found that this little 1/4” extended length ratchet is the magic bullet for interior work. It has the long neck allowing access without the body of the tool getting in the way, it allows one handed removal of fasteners and has enough torque to perform the job but not so much that it strips the plastic bosses out nor too fast where it over-runs the threads pulling plastic threads out.
When installing the new actuator it is critical for proper spline alignment or the HVAC actuator will not calibrate. This is why I had to pull mine back out and re-clock the splined last night as it wouldn’t calibrate.
Upon removing the actuator from the package this flat spot on the output shaft should line up directly with the raised line on the body.
See two pictures below.
To do that the recirculation damper door must be fully raised (open) before installing the actuator assembly. Mine was raised but dropped slightly as I was engaging the splined originally. It must be pushed upwards then instal the actuator into the splined damper door for proper positioning.
Lastly after replacement a bi-directional scantool will make life easier by running a calibration cycle.
For the Snap-on tools the test is under HVAC system, then special tests and lastly actuator recalibration. Thus will run all actuators through their range to calibrate. After a successful calibration or passed message you can complete reassembly of the dash.
Lastly here is the part number for the Jeep actuator motors.
Dorman also makes one that is popular but the NAPA one is made by Echlin and I prefer it.
***On EDIT, I would advise against using aftermarket actuator motors. I had hear horror stories about the Dorman ones so I used the Echlin from NAPA and also had issues. Within a couple of weeks of replacing it the HVAC module would not be able to get consistent current reporting feedback from the actuator and therefore would have to re-sink with nearly every ignition cycle.
I replaced the Echlin with an OEM Mopar actuator and problem solved. OEM Mopar actuator part number is 68018109AA.
The Mopar OEM actuator does cost more but save yourself some time and frustration by only doing the job once. It's not worth it using an aftermarket and gambling on whether or not it will work on this job.
Thanks for looking.
