I have been looking for a decent mobile miter saw stand for a while, and thought I would try my luck on the Masterforce MX124. I don't have room for the larger Bosch T4B, or similar Dewalt, and my local Menards doesn't stock the Bosch GTA3800. I want something with wheels as I store the saw/stand under part of my workbench, which has a max capacity of 64".
Well....it's a fail on many levels! The levers that provide tension to the horizontal telescoping sliding material arms/supports are too weak, and don't hold. They also allow the material supports/rollers to wobble very easily side to side. That that it is a huge deal, but that means the built in material stops are going to be worthless for repeated cuts. What is funny is the levers that hold the rollers/supports on the telescoping arms are extremely stiff. No consistency in the force required to hold them in.
My assembly process and evaluation stopped there, as there really isn't any point in going any further. It is disappointing, but I think I will have to spend a little more an go with Bosch.
https://www.menards.com/main/tools/power-tool-accessories/tool-stands-saw-horses/masterforce-reg-universal-folding-miter-saw-stand/mx124/p-1444436620008-c-1496857146263.htm?tid=-699892887595986506&ipos=2
Lever(s) in question.
20210104_162410 by Jon S, on Flickr
Pretty cheesy way to secure this lever, and long term I think the metal will easily deform from repeated use. So even if your new stand doesn't exhibit the same issues mine did, I am guessing it will eventually. As far as I can tell, the square telescoping material support is located in the round tubing by the plastic inserts. There is just going to be too much tolerance stack up for this to ever be a reliable setup imho.
20210104_162503 by Jon S, on Flickr
20210104_162410 by Jon S, on FlickrPretty cheesy way to secure this lever, and long term I think the metal will easily deform from repeated use. So even if your new stand doesn't exhibit the same issues mine did, I am guessing it will eventually. As far as I can tell, the square telescoping material support is located in the round tubing by the plastic inserts. There is just going to be too much tolerance stack up for this to ever be a reliable setup imho.
