Motive brake bleeder
C
CVPIJoe
I think I got what I wanted out of this thread and more.
Went to use this thing and the cap doesn't fit. The ford 3 prong one has the prongs towards the top of the cap and my actual cap has them at the bottom so it won't twist on. I am going to look at other options.
latebreak
Cedarburg, WI
https://www.motiveproducts.com/pages/application-guide
https://www.motiveproducts.com/pages/caps
From their website:
ALWAYS CHECK YOUR STOCK CAP BEFORE ORDERING. TAKE A PICTURE AND SEND IT TO [email protected] IF YOU'RE NOT SURE ALONG WITH YEAR MAKE AND MODEL
LVIIIR
SD
I love my motive PB. Makes life easy when you don't have extra help around!
engineer2
Chicago burbs
I have an older Vacula model (now Mityvac Model # MV6830). It works well but needs plenty of CFM to be effective.
It shouldn't take much. Unscrew the outlet filter to make sure it is clean. If the o-ring behind the filter goes bad, so does the suction. How far it is screwed in also affects the suction. On mine, the relief valve came apart, but I was able to kludge it together. The large container O-ring is available from Uxcell on Amazon.
M6erfan
'Merica!
"When operating at 90 psi the MV6830 will consume 4.3 scfm of air"
Maybe not much, but at the limit of my homeowner compressor. It's all relative.
M6erfan
'Merica!
Well, never mind. I was thinking the MV6830 was like the older Vaculas that used about 2 CFM.
My Vacula (DX2.5) "requires" 2.8cfm @ 87psi, but it works much better with about 50% more cfm. Which is 4.2cfm, on par with the MV6830 requirements. Makes me wonder if Mityvac recognized this and upped the cfm requirements. :dunno:
itwnexus
Has any one used the CTA Tools 7030 Master Cylinder Adapter - Compatible with Honda on their Motive brake bleeder?
https://www.amazon.com/CTA-Tools-7030-Cylinder-Adapter-Honda/dp/B01MYXAXS5/ref=sr_1_25?dchild=1&keywords=Motive+brake+bleeder&qid=1610146141&s=automotive&sr=1-25
$28.34
Ralf11
I use an old brake reservoir cap and drill a hole in it; put a male fitting for a hose, then clamp it
the adapter is $28, so I saved 25
