I changed my avatar.
chadster1
Terrell, Texas
A free CAT1100 to the first person that can point out what is different about my truck from the previous pic. There are two differences but I am looking for the difference that is the more permanent of the two. Only one correct answer and I am the final judge. I would prefer that only people that do not have access to a dealer guess.
filtered
Berks Co. PA
The wheels look chrome instead of white.
The Snap On plate is missing from the front bumper also.
mrshaun
Killeen - Fort Hood
you finally washed it. I thought it was kind of a dirt color like mine. it rains every couple of days so my truck is always dirty....
C
chadster1
Terrell, Texas
Awww no 30" spinners....
That would be a little too much bling.
fordbroncodave
i was gonna say, you took the picture when it was sunny instead of cloudy. same location?
mrshaun
Killeen - Fort Hood
chad looks like rain for you tomorrow. you washed it so now it must rain. plus the weather man ( big liar ) said rain in your part of the world tomorrow.
kool55
South Central VA.
chad, what advantages are there by having a chassis cab/box truck over the big step vans? Seviceability,comfort handling? I would think you lose some tool volume.Is the box heated and air conditioned?
C
chadster1
Terrell, Texas
Thanks for the compliments.
Yes, there is access from the cab to the box. I can also secure the box from the cab if I ever have to leave the truck for service. The cab and chassis drives a LOT better than the traditional step-vans that dealers have to start with. The weight capacity is another advantage. This truck handles the weight of my inventory without a problem. My last tool truck was a 16 ft step van on a Freightliner MT45 chassis. I had that truck overloaded with the weight of my inventory. I had to replace the front springs and right after that the body started cracking. That is when I decided that I needed a new truck. The box is heated and air conditioned. It is better insulated and I can keep the box cooler in the summer because I do not have the radiated heat from the windshield coming into the box area. This truck has an 18ft box. It holds more tools than the standard 16ft step van. If I had my perfect truck, it would be a 22 footer but when you buy used like I did, you take what is available at the time. A new 22ft truck like what I want would cost well over $100k
mrshaun
Killeen - Fort Hood
yeah the step vans are heaters the summer time. I have to have the smaller truck to get around in the motor pools on fort hood. I did have a 20 foot box on a 2 1/2 ton chassis truck when I started. way too big for what I did so we had to downsize. I hate not having the room but I can go anywhere a pick up could go...
My front springs are de-arching and the body mounts have broken a couple of times.
I popped the front rivets in the middle of the window one day. It sounded like a 22 going off. I had to drive through some rough terrain and the body twisted real bad...
C
chadster1
Terrell, Texas
My front springs broke! I only had 1 leaf left out of 6. Dont let yours go as long as I did. I was close to having a very bad day if that last leaf would of broke.
cronic
What kind of gas mileage do you guys get on these trucks? I would assume that other than inventory fuel is one of your biggest expenses?
mrshaun
Killeen - Fort Hood
with the ethanol now present in the gas my gas mileage went from 6-4mpg in most cases.
so it gets expensive my truck is rated at 15000 and it is right at 15000 and it is all run off of a 5.7 vortec 350. the honda generator will **** about a gallon an hour when I run the ac... luckily I do not have very many long hauls except on monday. I run about 100 miles total... 30 gallons gone with the ac on all day long....
