4500 watts on 20 amps
flat350
illinois
First off I'm a Plumber not an electrician,I want to run a 4500 watt water heater element on a 220/20 amp circuit.Am I pushing it with 18.75 amps on the circuit,it won't be 4500 watts all the time it gets dialed down after an hour or so with a controller to probably 1500-2500 watts.
Terry D
St. Louis, MO.
I personally would not do it. I always put them on a 2-pole 30. Im not sure if this falls under the 125% rule, if it does, you cant do it anyway. 18.75x125%=23.44. You might want to change that 220 volts to 240
F
flat350
illinois
A 30a circuit would be better,is there a reason you can't run a 30a circuit to feed it?
I have an existing 20a circuit there now,it would be easier I guess to get a 3500 watt element or lower.It's not in a water heater it's in a 1/2 barrel............
F
flat350
illinois
A friend of a friend said I could run 2-4500 watt elements on 240v in series and get 2250 watts at 9.4 amps,is this possible and safe?
Bert_
NW Iowa
How long will it be on? Doesn't sound like your actually using it for a water heater.
You can load it to 100% if it's less than 3 hours.
u2slow
BC
Possible and safe. Have done similar before. Code legit?... not sure.
That was my thinking. He says 1hr at full load. I'd give it a go for a personal project. Worst case the breaker trips on thermal.
F
flat350
illinois
Ran some numbers on the heat I need to make and I'll only need 3000w,that should make things OK on the existing 20a circuit.
nadogail
Coronado, CA
I often run into territory where what will work is different from what is permitted to be done.
Sometimes I just let my sense of decency be my guide, If the risks are acceptable and the probability of loss is negligible, I just might accept the risk and liability of doing what I can get away with.
