Do I need to extend my electrical boxes
Mainiac Mat
Maine
Truss framed ceiling with 3/4 strapping and 5/8 fire rated drywall....
I mounted my blue poly light boxes as low as I could go on the bottom cord of the truss.
They do not extend fully to the bottom of the hole in the drywall... leave about 1/4" to 3/8" of the drywall holes showing.
Is this not big deal?
Or do I need to put an extension on the boxes?
If extension is required, do they even make them for the blue poly boxes?
Thanks in advance for any tips.
Terry D
St. Louis, MO.
Article 370-20 states they can set back no more than 1/4" from the finish surface. I don't understand why you could not have brought them down more, plus they make adjustable boxes. They do make box extensions for the blue boxes. It is a code violation if they set back more. its up to you if you want to use extensions or not.
https://www.lowes.com/pd/CARLON-Blu...dard-Box-Extender-Wall-Electrical-Box/4411965
pattenp
Virginia - USA
1/4" is the max allowed by the NEC that the front edge of the box can be back from the drywall finished surface.
Mainiac Mat
Maine
Thanks for the help.
I bought the standard (inexpensive) Carlin blue 4" diameter boxes and nailed them as close to the bottom of the truss as I could get... which (unbeknownst to me at the time) doesn't span the 1-3/8" needed to bridge both the strapping and sheet rock.
I didn't mount the boxes to the strapping because the attic deck is already in, so I had to install insulation from the bottom (staple up kraft faced fiberglass) and it's a lot easier to put that in before the strapping.... but rough wiring had to be done before the insulation....
Once I got the strapping up I could see that the boxes were going to be high... and sure enough, now that I have half of the rock up... there's a gap.
Seems like a non-issue and I've already had my rough wiring inspection... not sure if I'll just use as is, or get the Carlon extensions.
Terry D
St. Louis, MO.
What I linked was for device boxes, I would imagine they would make a extender for round plastic as well
Mainiac Mat
Maine
This is the product Carlon makes.... they call it a "Plaster Ring" and it steps down from 4" dia. to 3" dia. and they come with either a 1/2" step or a 5/8" step.
Looks like a workable option....
Mainiac Mat
Maine
You had me scared there for a minute....
Though not ideal, it appears that I'm code compliant...
66cj225
NH
Thanks for the info, I was just guessing. Now I'm going to toss a blue box in the wood stove for chuckles.
66cj225
NH
The box that went into the stove had a UL BH122 and kind of a glass mat finish. It didn't support combustion but became a totally different shape by melting (blob) within 5 minutes.
Mainiac Mat
Maine
Not exactly UL or ASTM testing standards... but a little unsettling just the same. But if you have that type of intense fire, I think you're screwed regardless.
mobetta
twin cities, mn
Yeah i think its pretty funny that I had to make a "firewall"(5/8 gyp both sides to roof deck) on my lot line wall but theres is absolutely no care given to the wiring/boxes/penetrations on that wall.
I did use putty pads on my PVC outlet boxes but NOT NEEDED....
