George-in-NH
- Joined
- Oct 27, 2016
- Messages
- 23
Hello,
I am planning a DIY installation of Slab Radiant in my garage. I've gleaned a ton of useful information from this forum and I thought I'd document it for feedback and to show the process incase it can be of help to anyone, someday.
Project Stats:
Detached Garage - New Construction.
28x32x12 Wood framed garage, with Attic Trussed room above.
No domestic or any water at all to the garage from the house.
Insulation is R19 walls and Spray foam against roof and gable ends. It's tight.
(2) 10 x 9 Overhead Doors (R14 Insulated).
(1) Man Door.
(5) Windows Down & 2 Window Upstairs.
Slab (5" Thick) already has 4 loops of 1/2" PEX (O2 barrier) about 200' ea.
Slab Insulated on inside of 4' frost wall (down to footer, 2" XPS Dow Blue).
Slab Insulated with CreteHeat EPS panels under - These also positioned the PEX.
I installed Electric Baseboard upstairs that will be used when room is used.
I have pulled permits for all of my work including this heat install - We are allowed to do our own work on a primary residence here in Seacoast NH.
Usage: Car Parking and Hobby workshop for cars, bikes, anything else I want to! I plan to run one temperature all the time maybe 50-55 depending on how it feels.
Boiler Selection :
I decided to do Slab Radiant but I've never been in a garage with it so I hope its worth the extra $ (at least 4X a Modine).
LP fuel but maybe going to NG in the future, my house has it but hard to get access for garage.
A Mod/Con was chosen so I can run low temp and stay in the efficient range of boiler.
During my research, I have found that there are not many small sized boilers available. I tried to get a Navien NHB-055, the specs look great - However Navien does not allow them to be sold to non licensed individuals. Then I placed orders for a Triangle Tube CC50S, then later a ZBR 16-3 Greenstar 57 45,000 BTU. After ordering I was informed that both are discontinued. That cost me a month of time and brought me into the cold part of the year, oh well. What I have come to realize is that the smallest sizes seem to be limited at the high end output but otherwise seem the same.
I have only been considering purpose built boilers and am staying away from Tagaki etc on demand water heaters. Hopefully this will increase reliability, because it sure increases cost.
My current design uses a Weil-McLain AquaBalance Series 2 WMB 80-H. This is a heat only boiler with a 10:1 Turn Down Ratio for a min burn of 8kBtu/Hr.
I am ready to place orders for the equipment - I'm buying online from supplyhouse and ecomfort to avoid the attitude I get at the supply store counters when I say I'm installing my own system.
Design:
I'm using Primary/Secondary per WM Manual. To make things easier, I'm using the WM pre-fabricated Primary Manifold. Antifreeze will be used and there is no source for make-up water. I intend to pump neutralized condensate thru the wall our onto the ground. If I have condensate freeze up issues, I'll add heat tape.
See attached schematic of my system design (and the WM piping diagram from the manual). Any comments are welcome and appreciated.
George
Edited 210111 - Diagram now includes Spirovent and 3 Zone Taco Relay
Project Stats:
(1) Man Door.
Boiler Selection :
Design:
George
