Well, had a wild idea to construct a top bow cover for the Command Car out of canvas. Figured I need to learn to sew, so might as well make some things that hopefully will be useful
First had to pull the canvas top off the bows:
The bows fold like regular style convertible top bows, but the sit on the package tray metal on metal:
The bows don't quite sit lever, but found if I strapped them in the center, it would keep them level. Be a lot easier making a symmetrical cover. Well, easier said then done:
Roll out the canvas...when I bought this they folded it. All the other canvas I have bought came in rolls. Folded canvas just isn't right:
Making a template:
I wanted a bit of a cushion, so I picked up some of the carpet runner at home depot. Probably about 1/8" think with carpet like those classic shop door mats.
I cut two canvas sections to sandwich the rubber in between:
Rubber:
I tried everything to keep the rubber perfectly centered within the two pieces of canvas, but the rubber still migrated when I sewed it in place. Mostly left to right. I trimmed the one side off and added a little tad to this side:
I wanted about a 3" strip of canvas on the interior side of the cover, but I had those angles. When I looked at it, I could see how it would bunch up if I didn't do something different. Finally decided to cut the strip at the angles. Had to cut them at an angle as well, and then sewed them together. Actually worked out ok. Here's where I want to add the strip:
Strip with the angles all sewn onto the bottom cover:
Then I wanted to add some binding all the way round the bottom section. It was a workout, but turned out pretty good:
Binding all done, plus I had to add a couple of cut outs for the bow straps:
Here's a shot of the front/interior side like I was trying make it:
My wife thinks I'm nuts learning to sew, so she shot this:
