JIS Philips
theoldwizard1
SE MI
Should I buy a unique screwdriver or just get 1/4" hex bits ? #2 looks like it covers 90% of all application.
Recommend a JIS #2 screwdriver.
ChevyEFI
Phoenix, AZ
We've had this thread a few times before. Some Vessel on Amazon was gifted to a family member at xmas time. :)
Kev442
Wi
I bought bits. Only use JIS about three times a year.
RoundedNut
driveway
Vessel ball grip handle: https://www.amazon.co.jp/dp/B00E55DL5C/
Vessel assorted bit set: https://www.amazon.co.jp/dp/B0751891B5/
The Japanese bit standard and holders are different and much better. They hold the bits deeper in the recess and firmly with none of the usual wobble.
You can get reduced shank bits that offer better clearance and better fit on the smaller screw heads that are still PH2. Bits have higher hardness than regular screwdrivers by standards so they last longer, and the common Japanese double ended bits double the lifetime.
macgee
Sepulveda Pass, CA
I would buy a vessel #1 & #2 screwdriver, they're priced well delivered to your door and I use mine every single day for all cruciforms in that size, it's replaced all of my other US Phillips screwdrivers. They bite way better and will never go back.
Suggest either trying the Vessel Super cushion 700 or the hard handle Megadora 900 version that has a similar feel of something between the Williams black handle and the SK 79113
handle.
https://www.amazon.com/VESSEL-CUSHION-Screwdriver-No-700-700P175/dp/B087JLML62/ref=sr_1_3?dchild=1&keywords=vessel+700+screwdriver&qid=1612492221&sr=8-3
https://www.amazon.com/Vessel-Megadora-900-Screwdriver-Original/dp/B000TG8OTY/ref=bmx_5?pd_rd_w=ZkYxw&pf_rd_p=82aca571-3653-4c76-afa2-d596d18861b7&pf_rd_r=8RTK8QXC9FAGQ535JEZZ&pd_rd_r=405e430a-9d57-4066-b70d-4ceb575463ef&pd_rd_wg=zx0F0&pd_rd_i=B000TG8OTY&psc=1
If you like them, then invest in bits but I prefer using a solid driver whenever I can. You'll get a better feel of it as a solid screwdriver to see if you like it. I also also suggest to try out a PH#1, You'll experience a lot less cam out on those small cheap crappy soft screws.
As mentioned earlier, there's been a slew of recent threads on this subject if you want more info.
EDIT: RoundedNut made a good point, they're selling the ball grip label as a Craftsman for like $7. They're also really good to try out. it's a double ended blade, not as solid feeling as the ones listed above but still good and don't let the ball gimmicky look fool you, its actually pretty nice and can offer all kinds of solid torque. Here's a USA Amazon link to it.
https://www.amazon.com/CM-SCRWDRVR-PHLLP-CDU/dp/B01CH1I2RC/ref=sr_1_3?dchild=1&keywords=Craftsman+Ball+Grip+Screwdriver&qid=1612492045&sr=8-3
M6erfan
'Merica!
Household stuff #2 is common. Automotive/motorcycle, #3 is common. Electronics, #1 is common.
I rarely use bits, I prefer solid shank drivers. Vessel, Sunflag, Anex.
cheechi
Triad, NC
I own some bits, Vessel drivers (including the craftsman Impacta set) and the HF set, and the HF set are the ones I use the most.
Because of upstairs/downstairs I actually have Vessel & HF in two tool boxes at home and in both cases it winds up being the HF ones. The Jawsfit is a very useful style to get but not every situation calls for that.
lardy1
I'm a recent convert. I bought three sizes of Vessel Megadora with Jaws Fit and I love them. I also bought assorted Felo, Wera and Wiha phillips style in various sizes. All are an upgrade over Craftsman and that level of driver. I still like my Kleins but the others are nicer.
CoogarXR
I bought two Sunflag screwdriver sets a while back. I use them almost exclusively when I need a philips.
Shelbylex
If we are speaking Vessel, then the question always comes: go to Megadora Impacta 980 #2-10 vs #2-15 (difference in length, not sure if there is any downside just going 15cm longer one from the beginning) and #3-15 or pick up the other ones? Seems that having a build in impact mechanism could be a big plus in case you need them. Unfortunately there is no #1 in 980 version.
Was doing rear brakes on Acura this year - wish I had known about JIS and bought those - would have saved me a lot of time on 2 stripped rotor screws...
M6erfan
'Merica!
I wouldn't' recommend the Vessel Impacta as your only, or first, JIS screwdrivers. Their Megadora 900 series is much better for everyday tasks.
Shelbylex
Thank you, M6erFan and 4xdog. Why do you prefer 900 vs 980 impacta? They appear the same visually (I wish I could see them in real life in the store...). Or does the impact mechanism give it less rigidity or more free movement when used as regular screwdriver?
I am actually planning to add a couple of Vessel screwdrivers to my collection - I have couple of Snap On (Ph1, Ph2), Ph4 Proto, and some Husky from my old days, but would like to have the type of screwdriver which does not cam out (+ probably impact after my summer brake experience)
Fatboy148
Weight.
ETA.... For me, it wasn't prefer, it's in addition to. I started with the Impacta and then added the 900 series JIS tips.
Shelbylex
Thank you, Fatboy148. Did not think about the obvious. I might go your way starting with Impactas and adding. Will need to find some sale for them (as I do not need them urgently) with the next holiday sales...
4xdog
Santa Fe, NM
Thank you, M6erFan and 4xdog. Why do you prefer 900 vs 980 impacta?...
I like the shorter length (of some of ‘em) and the knurled shafts on the Megadora 900 series. I like the Megadora 930 series too, with their hex bolsters.
For the Impacta series the Craftsman-branded JIS cross-point and slotted tip combination is excellent. A very good price (abt $15 for both) and the slotted Impacta is something one can’t get from Vessel. I used it successfully the other day to remove some old wood screws from the hinges on a basement door being refinished at my place.
macgee
Sepulveda Pass, CA
I found that I don't need or want the heavier, less balanced drivers for everyday use, I only need them about 1-3% of the time but good to have one when you need it. Like 4xdog, I also like working in shorter lengths.
If you don't want the Vessel serrated jaws fit tip in Megadora. JDV (Vessels US Distrb.) is the only one who sells a standard JIS non serrated jaws fit tip version or your can buy the Super cushion 700 that also does not have the serrated jaws which I actually prefer non jaws fit for everyday use, tip lasts longer and doesn't mar up the fastener as much but Jaws Fit do work well.
https://vesseltools.com/handtools/screwdrivers/megadora/900-series-detail
Shelbylex
Thank you, 4xdog and macgee. I guess I will need both : )
m3bs, thank you for the reference. Excellent review!
Fatboy148
Ralf11
Vessel also make a handle designed for dirty, greasy work
I forget the series number but it's got black nubbies on the handle and somebody posted info on here
4xdog
Santa Fe, NM
Anex is another made-in-Japan driver specialist. Their new driver is both a regular AND an impact driver in one...
Are you sure that Anex is an impact driver? It's not clear from any description that it turns a screw when struck, like a conventional impact driver and the Vessel Impactas (at 12°/strike).
The Anex looks like a special hardened tip that cuts new driving surfaces in crosshead or slotted screw heads. The idea seems to be that with a new head cut the screw can be turned conventionally.
darkzero
SoCal
Yup, sounds like you are right.
Translation from the description:
Hit with a hammer to make a groove
By hitting the washer with a hammer, a specially shaped cutting edge creates a new groove in the screw with a crushed cross hole.
You can also remove the tanned screw by rotating it while pressing it.
darkzero
SoCal
I'm still skeptical about the Vessel Megadora Impacta. I have one, it does seem to work, & the thing is much heavier than my regular Megadoras but I can't feel the turning mechanism like with a Lisle or SO impact driver.
I just wanna see someone cut one open! :)
