Crow Horse
I've searched and haven't found the info I'm looking for. I'm in the home stretch of converting a garden sprayer into a fluid transfer pump so that I can fill my diffs and t-case without the usual mess. I've drill/tapped for a gauge and I want to use a thread sealant so that this connection is leak free. Most of the thread sealants require a metal to metal joint to cure. Is there anything available that will seal threads for a metal to poly connection?
Pictured is the tank with a brass ****** threaded into it for visual purposes. The gauge that will inhabit it is a back mount gauge.
Edit*** The pressures will range from 15-20psi.....
