Another Delta 17-600 Thread
gjohnson
I recently picked up a 1944 delta 17-600 and I am going through it making things right for now. At a later point I will completely tear down, strip, replace the quill bearings, and re-paint. As of now I have replaced the improper motor drive pulley with the correct 5 step slow speed and belt, replaced shaft collar bearing, fixed wiring, welded up the holes in the cover and replaced a missing bracket on the lower cover.
I have also replaced multiple improper fasteners throughout and done some cleaning. It came with a VFD and has a 1 HP motor. Does anyone know what steps would be best to use with this combination ?
I am missing a couple of parts to make it correct: The 795-s knob screw for the cover and a feed handle ball. If anyone has these pieces and is willing to sell let me know. I would also like to replace the tag or restore if possible. It is the Milwaukee not Rockwell.
The table is horrible and has a base plate bolted to it. I am debating tigging up the holes with ni/cu rod. Or finding a decent used table to replace it. Kinda hard to find and this is already turning into a money pit (seems to be the story of my life). It has the production table and the rack works great.
I have also picked up an 882 light that cleaned up nicely and would like to see how it could be mounted. I have some ideas but would like additional opinions. I am thinking about making the original style L bracket and mounting it using the bottom cover or quill return spring fastener.
tarbellb
Oregon
Nice looking machine, good job on the progress so far.
As for the table, sure, they are out there, but big money typically. I think you are better off just repairing what you got.
Keep us posted on progress.
slowtwitch73
Hellgate
I have the same drill and put a drilled and tapped aluminum table over the original. I use a small milling vise on it and it accepts standard milling hold downs. I can hold down the vise if I want or clamp down whatever needs drilling, put dog in to prevent parts from spinning, etc.
G
gjohnson
When I get the base plate removed I’ll show some pics. It is really bad, I can fix it no problem but time vs cost is becoming more important to me as I get older. There are giant holes in it, would definitely take a chunk of the day to fix. Then convince my neighbor to re cut the surface.
G
gjohnson
I like this idea, do you have any pics ? I’m scratching my head wondering how to clamp down on a flat table. 1/2” thick ?
