belt size? valve grinder
volaredon
IL
I have an old (40s?) Black&Decker valve grinder, set up as a "dry" unit with a makeshift funnel to hang behind it for lube. I have been working on it a bit, got new rubber motor mount studs, replaced the power cord, it works, runs but I need belts. Anyone have a length and/or width?
Its in the garage, I'm in the house. I can get the actual model number(s) from it if need be.
Got a bunch of stones and the seat cutter with it. No not for sale.
I have run an old Sioux valve grinder before, and have enough small engines here (mostly cast iron Kohler stuff) to mess with to keep me busy with it for a little while and a couple of Slant 6 and 318 heads here to refresh myself on the fine points of head/valve work, that it will come in handy for....
laser3kw
northen IL
I had an old valve grinder. Can't remember if it was a Sioux or a B&D. I believe it had a flat belt - leather I think.
V
volaredon
IL
No this one takes a v belt, actually 2. 1 to run the grinding wheel side any 1 to run the valve stem spinner (for lack of a better way to put it)
V
volaredon
IL
ok here's what numbers I can find...
"Super Service Valve Refacer"
Size; 9/16"
Type N
Serial 1169809
on the other motor; "Work Head" 110v 1.3A Assy 20575
there is a belt going to the "Work head; would this be the same belt as the other side?
(does it take the same belt on both sides?)
Dumber than lumber
What about checking that Vintage Machinery website?
Let’s see if i can find the address.....
Sorry - looks it is more about woodworking machines.
American Locomotive
Rhode Island
BUMP Cmon... nobody?
You have a ~60-80 year old obscure tool! It's not too hard to just measure for the belt you need. Here is a handy calculator:
https://www.omnicalculator.com/physics/belt-length
Then you just need to determine the section:
https://www.powertransmission.com/issues/0617/vbeltsfig6.jpg
It will almost certainly be using "fractional" or "L" series belts. If you can find on in the right size, I recommend getting a "cogged" or "notched" v-belt.
One you get the number from the distance calculator, and the section type based on pulley width, it's just a matter of putting it all together. If you determine you need a "4L" section and a 37" long belt, you just need to find a "4L370" belt.
cidermill
Huntington, NY
be. good luck!am equipment, meyersdale,pa 301-842-7095 they have belts stones and manuals in stock you just need the model number good luck!
pepi
Woodstock, GA
A piece of rope, 3/8 - 1/2 dia lay it in the groove, without stretching it, will get you in the ball park.
easy
