Challenging gutter install
MatBirch
Filer, Idaho
I'm having trouble finding a solution to install a gutter along the eve of my covered porch. The fascia is good 3-4" behind the edge of the roofing material. A traditional bracket will put the gutter almost completely below the eve. Some sort of a standoff seems easy, but I'm afraid of the torque involved when the gutter is holding 6" of wet, heavy snow. I don't particularly want to fur out the entire length of building unless absolutely necessary.
Captain Spaulding
Southern Indiana
I would think a treated 2x4 furring board is going to be the easiest solution. That will put the edge of the roof at the center of a 5” gutter if the overhang is 4”.
Dustball
Hudson, WI
A few ideas with this Google image search- https://www.google.com/search?q=roo...ECAgQBA&biw=1536&bih=732#imgrc=Ht9SvpwFV-2GiM
hung_cu_gutter_rodsnnuts_on_asphaltshing_with_hangers_on_white_background_1_480x480.jpg
Kaizen
New England
I am wondering why it would have been built that way. Someone is anti-gutter?
Guessing it had crown molding at one time
I had gutters in my house from 20 years ago that used the brackets above. They were aluminum. Very sturdy in one direction which is all they need
Bert_
NW Iowa
Not crown, Bedmold.
Bedmold is supporting moulding.
CraigStu
Blacksburg, Va
Roof is metal... added as a remodel. The new
metal just about doubles the overhang.
Now we know why it is that way. I suspect there is no drip edge molding correct? So the longer metal overhang forms it's own drip edge. It doesn't seem like a common wider gutter (6 inch) would do you much good so I think a spacer board is the best solution. Treated (w/ solid color stain) or plastic. I'd prefer the plastic but usually it is more expensive. But if white works, and current treated wood prices + stain costs, may make plastic wood the solution.
