Battery operated continuity tester
kabinenroller
S.E. Wisconsin USA
I am interested in locating a quality circuit tester to be used for automotive applications. The type I need is battery powered (not for live circuits)I also prefer an LED and a flexible rubber cord, not a cheap stiff wire.
Does anyone have any experience with a unit like I have described?
Thank You!
dogdog
there is that glorified ,,,, power probe maybe ? if you are into those stuff... I have the PP3 sets.. but seldom used it since the multimeter is more handy and next to me.
K
kabinenroller
S.E. Wisconsin USA
I guess I should have been mentioned that I am looking for a tester that resembles this:
doctordirt
I have a test light without battery, digital multi meter and a power probe. What is the advantage of having the battery powered test light, is it just in form factor and ability to do continuity?
Wrench97
Southeastern Pa
It does put a slight load on the wiring/connections to light the 1.5v lamp that a digital ohm
meter will not but there is no substitute for the actual load.
In other words a DMM will actually show a connection on corroded/wet connections that will disappear when a load is applied to them.
CoogarXR
I have the Vaco model 70008:
These can be handy sometimes. A little less "clunky" than a meter if all you need is a quick continuity check. It's nice when working in a dark, confined area, under a dash or something.
There's one like mine on ebay right now (no affiliation) pretty cheap.
