could i use these for tool storage?
AndrewBigA
LONG ISLAND, NY
i came across this randomly tonight. the metal drawers hold a good amount of weight & they are pretty dam cheap. i will be building a new desk really soon. i was thinking of a way to put a tool chest underneath, then i was going to mount a countertop on the top. i think this would come out to alot cheaper & seems like something that could be fun to build.
i can have 2 rows of these metal drawers going from the floor to about 30" in height & a few feet wide.
check this out:
http://www.cabinetmart.com/shop/Drawer-Slides.3
i wanted to share this with all of you. maybe someone else can use this to make a custom tool storage unit? maybe someone needs a few extra shelves?
how would you build something to hold the shelves in?
thanks for anyone that can help me out with some ideas.
lilredex
Toronto
Missed that................
Not that hard to make something like that. Lots of free material around like stoves, washers and dryers etc. Even easier if you make up some type of brake. Do a search for a DIY sheet metal brake (gingery brake) for many types available.
Example of material I picked up..........
A
AndrewBigA
LONG ISLAND, NY
cool but i dont weld or build anything with metal. i always wanted to learn how to weld but never had the time. i would be building something out of wood.
danski0224
Near Naperville, IL
check this out:
I bet the cost of those metal drawer inserts will add up quickly.
You might want to consider a couple of short toolboxes with the top of your choice as a desk surface. A couple of companies offer these work stations in several combinations.
Making the cabinet carcass and face frame is standard cabinetry, not my realm of expertise.
Those discontinued Lee Valley drawer inserts don't look too difficult to make. The back corners aren't closed. The front/pull is probably separate from the bottom/sides/back, and spot welded on. Pop rivets could be substituted for welding or soldering. Yup, I could make these pretty easily.
danski0224
Near Naperville, IL
yes, this would be perfect & cheap as hell lol!
If you really like those, maybe you could find someone to make them for you.
Making one wouldn't be very cost/time effective, but say 10 or 20...
You could have someone form the 2 pieces and then do your own drilling, riveting and final assembly to save money.
Diesel_Crawler
Canada, NB
This is a very popular road tool box, also for home use and can be got cheaply in many colors to make it your own.
rrudd2
Petersburg
im glad you can make them but i cant lol. im looking for a cheap way out. i have a few more shop projects to take care of within a short period of time. im trying to save some money.
Do a little bartering. A friend, or a friend of a friend, has the skills to build you a tool cabinet. You have the skills to make his or her car shine. Trade.
tylerae40
western Australia
if your still looking for something like this- check out your local disposal/ dump store. I did a job for a mate a while ago. I took apart a couple of metal, office filling cabinets and made up some brackets. I then welded the brackets to the bottom of the bench and bolted up the slides and the boxes to that. They work well and still does the job as far as i know. i plan to do a similar setup when i setup a sea container as a workshop.
If you keep an eye out, as said before you can find alot of scrap metal and bits and pieces for free that you can press up and weld to make drawers or projects out of.
good luck mate
