Well, I don't know which tilt arbor fence is the same. I have a fence here from a 103.22161 which if my memory serves was the same as the 103.22160 saw and it is different. It will clearly work when I get around to cutting it down but it is different.
Here is an image of the two side by side.
The band saw fence and rail system is on the left. The table saw fence and rail system is on the right.
That said, you are correct in the fact that it can be cut down. It has an aluminum body and can easily be cut with a miter saw and be made to fit.
View media item 111022
