Craftsman 103 bandsaw accessories
Mustang67ford
I have an older craftsman bandsaw #103.24280. Anybody know the part number for the miter gauge or rip fence? When I search online, it looks like there was a 103 model table saw and thats what usually pops up.
FrankLee
seMI, 48317
subroc
Dover, NH
The 1955 catalog lists it as a 9A2246 the same number listed for their bench top table saw.
lafester
Northern CO
I was just going to say the little tilt arbor saws use the same fence, but you do need to cut it down a little to fit.
subroc
Dover, NH
Well, I don't know which tilt arbor fence is the same. I have a fence here from a 103.22161 which if my memory serves was the same as the 103.22160 saw and it is different. It will clearly work when I get around to cutting it down but it is different.
Here is an image of the two side by side.
The band saw fence and rail system is on the left. The table saw fence and rail system is on the right.
That said, you are correct in the fact that it can be cut down. It has an aluminum body and can easily be cut with a miter saw and be made to fit.
View media item 111022
lafester
Northern CO
I actually meant tilt table saw, sorry. I posted about it a couple years ago with pics.
Sent from my SM-G970U using Tapatalk
lafester
Northern CO
Only pics I can find at the moment.
Mustang67ford
Just ordered an old fence and rails off a craftsman 103.0209 table saw. I'm thinking this is the right setup and will just need to cut the fence down some.
Mustang67ford
Got this fence installed. Turned out good. Added 1" hardwood to each side as opposed to cutting the fence down. Issue I am having now, is my blade changes position on the wheels each time I start it up. Not sure what is going on with that. Sometimes it drifts back like 3/16 or if it didnt drift, it whill the first time I push in to make a cut.
subroc
Dover, NH
Alex Snodgrass has an excellent band saw adjustment video on YouTube. It is surely worth a look if is an adjustment issue.
Mustang67ford
Thanks, Had watched them before. Didnt see anything on the blade moving on the wheels.
I would think blade tension is low, or your blade guides are not in place correctly.
trpted
Cleveland, Ohio area
I recently purchased this same model band saw and I lost one of the blade thrust rollers in transport (since there was no blade in it at that time). I found the owner's manual with a complete listing of the parts (with part numbers) but have no idea who might have any. This manual doesn't show a fence or miter gauge either. I have only begun to look for the part that I need and would appreciate any info you might have. I will also be happy to let you know if I come across any source for the fence or miter gauge that you are in need of.
11b30b4
GA
You can find many of the parts on ebay. There are original and newly made thrust bearings available on ebay as well. I use cold blocks on my my saw. check out my saw thread for part numbers etc.
