Astro_Pneumatic_Tools
Not sure if it would be cost effective, but I would want 3 per set.
We'll pencil it out and take a look at it.
I said it before but I'll say it again, Astro is on the top of my list of tool choices.
We just have drawings, but it's as good a time as any to to get it into production. Works with a simple ball bearing to be able to rotate freely and not damage the knuckle. A couple sizes, a couple pieces per size. Should be pretty affordable, take a few months for manufacturing and testing though.
Is there a reason not to use the Astro rotor/hub puller here (notoriously frozen, you'd basically have to get the spindle off to get the drive shaft out, or other)?
I used it to pull a unit bearing recently from an '02 Ram 2500, but you need something for the forcing screw to push on. In this instance it forced the axleshaft against the carrier center pin, which actually doesn't hurt anything but the u-joint makes it hard to get a "direct pull" as the knuckle wants to flop left or right.
With a CV I don't think you'd ever get it to work unless you could "plug" the hole where the stub shaft would normally reside.
STILL WISHING FOR A BJP1-FIGHTER, ASTRO!![]()
The best way to pull hubs with it is to not push against the shaft but to take the CV shaft out (by disconnecting some of the suspension/steering components and pulling the spindle away from the shaft) then the puller nut goes behind the bearing and the arms push against the face of the spindle. I know that Eric has both the Hub Grappler and the Astro 78830 but am just wondering why he didn't go that route....either this type of hub laughs those tools off, it is too much work to disconnect the suspension bits, or he just wanted to show another technique.
Now I know where you get your ideas from ! (Watch the video, read the comments !)
Wheel Bearing Removal Trick
Unfortunately, while we're making it for international customers and a modified version that performs a different function for a private label in the US - this item as it stands is *******. Too many toes being stepped on and out of my hands, no forecast on this one anymore.
It is unlikely to be offered in the US.
I have not been able to find the internatiinal offering, either.
This is the tool I was most looking forward to from Astro as well. I'm really disappointed they aren't offering it here.
Is there any plan to add XL ratcheting wrenches to the Astro line up? Similar to the Mountain/EZ Red.
There's a patent on the FWD/REV action and the extended black part of those ratchets. I had prototyped some great non-slip style 6-point 100 tooth XL ratcheting wrenches. But they were a bit costly and just barely penciled out, then materials in Taiwan went up 15% and now they would just cost more than we think the tools should to you guys.
Nevermind, I found it. Ratchet wrench with sealed reversing lever:
Application filed by Snap On Inc
1999-03-18
Priority to US09/271,968
1999-03-18
Assigned to SNAP-ON TOOLS COMPANY
2000-10-03
Application granted
2000-10-03
Publication of US6125722A
2019-03-18
Anticipated expiration
Status
Expired - Lifetime
or
Reversible ratchet mechanism
Application US85862A events
1961-01-30
Application filed by George C Jenkins
1961-01-30
Priority to US85862A
1963-07-09
Application granted
1963-07-09
Publication of US3096659A
1980-07-09
Status
Expired - Lifetime
There are many others though and most with no expiration dates.
Wasn't a business strategy in this case, we're literally not allowed to sell it in the U.S.
That's as much as I can go into it
Been sold out for about 6 weeks. Our next shipment comes in last week of this month. So a couple weeks. How that works out for retailer timeline i'm unsure, but i assume shortly after that time.Any information on availability of an APT-321 ONYX micro orbital DA sander?
I've had one on order since January and was told 2/17, then 3/4, then 3/12, then a couple of days ago 3/29 and now I get a 4/1 as possible shipping dates.
Any update on when it will actually be shipping would be helpful.
Thank you.
You'd need to pop out that flat circlip, then it all comes out quite easily as long as you keep track of the pawl spring. Outside of soaking it in oil, can't think of another way. If the backdrag really is high, which they aren't in my experience, we can just swap your out for new if you have no luck. Let me know.Has anyone opened up the nano ratchets to lube them?
I got the 91210 and 93808 as birthday presents. They both need some lube (the back drag on both is really strong). I tried to pop the circlip out with no luck. Any ideas?
I love the size of both of them
Chris, rather than oil the best lube I've found for ratchets that are a ***** to open up is ATF. Slippery **** that can creep into anything.
My daughter bought them from Amazon and we are outside the return window so exchanging them isn't an option.
I'll try the ATF this weekend, hopefully that will resolve it.
You don't need to worry about Amazon, we're right here. We could take care of it
I have about 200 rivnuts to install. I have the Astro 1427 and it is taking too long.
Which air tool do I want?
Depends on size, probably PRN1 or something like PRN516
Right now I am working with M5 but I use up to M8.
Thank you.
Any more information on the availability of this ATP-321 DA Sander? I kept getting pushed back dates on when it would be available and then yesterday I was refunded my money from the vendor and cannot get any response as to why after a couple of emails? Is it no longer available?
I've had it ordered since mid-February. Should I just find something else that will work for my application?
We've had inventory for about a week. Maybe they cancelled on you just due to it being open the max the retailer allows it to be back ordered.
PM me your address, we'll ship you one free of charge for the hassle and to make sure you get one.
