Astro Pneumatic Tool Company
Fedwrench
Valley of the sun
Hey Chris,
Since this year's SEMA show was virtual and you guys didn't participate in it, I'm missing my annual fix by not seeing all of your new products for 2021.
What's new for 2021 that you can share with the common folk?
Thanks for continuing to release great products and for hanging around the Journal. Life here for a tool rep can be difficult at times. :beer:
A
Astro_Pneumatic_Tools
South El Monte
Hi Chris,
I purchased your Magnetic Spark Plug Socket Set# 94404.
I created a thread about them here: Spark Plug Comparo.
In this case I believe its referencing the minimum and maximum in the ASME standard for the socket type, being made to the minimum and following that the whole length for the socket. If you took it as "Were smaller than [my favorite brand]" apologies, we have several brands we potentially manufacturer for and thus usually meet certain set standards which can sometimes limit "custom" design freedom in these categories.
Hey Chris,
I can only share links to what's newest on our website so far, what I can't do is mention the new underhood light options we have coming out, the 3/8" nano impact socket set that goes to 24mm or the flex head impact wrench
Like I said, here you go:
https://www.astrotools.com/800-lumen-rechargeable-slim-light-w-quick-swap-system.html
https://www.astrotools.com/hd-magnetic-worklight-suction-cup.html
sweet victory
USA
Fedwrench
Valley of the sun
Thanks, I'm looking forward to the things you can't mention. :beer:
This reminds me, I am going to order some of those lights from the earlier in the year special as Christmas gifts. That thing kicks ****.
mfewtrail
Will Astro also offer a fill-in set(or maybe the option to purchase individual sizes) for those that already have the current 3/8 nano sockets?
theamcguy
Fayetteville, NC
Have the pdf product info sheets and marketing flyers been done for the Nano Ratchets 91210, 93808, and 93812? When I go download them off the web site I keep getting an error. Thank you
nmk_61802
Central IL
Always love the BOGO's that Astro offers, they always get me to try new Astro tools. Any thoughts of offering the Nano Low Profile Socket sets and 93812/ 93808 Nano ratchets on an upcoming BOGO?
A
South El Monte
I'll try to mix up something special order.
I'll ask IT about it, i know they exist.
I (like me personally who tries to swing these BOGO's which are a $ losing proposition) can only pull them off on brand new product I've been working on as a way to sort of get the ball rolling and get the word out.
On product that's no longer new it's harder for me to do anything like these as they aren't my babies anymore, especially on items that sell really well or we're even out of stock on.
Snapped-off
Indiana
Trying to help out a stranger on the internet.
This is one of the QD fittings from the master coolant pressure test kit. Are these fittings available anywhere to buy? Are they standard fittings in any industries? FB_IMG_1607991580156.jpg
f575gtc
Noticed the straight die grinders with quick lock / quiet operation, like the 206QL and 216QL haven't been made for a while but the right angle variants like the 205QL still is, can any reason be shared as to why the straight versions were discontinued and if we will ever see replacements?
signcrafter
Ran into an issue today with my astro exhaust pipe expander. I love this thing and have posted many times about it. But today I was doing some exhaust repairs on a vehicle with 2" OD tubing. Usually I'll buy a stick of tubing to slide in one side and expand the other side and call it good. Well the small expander jaws go up to 2" and the bigger expander jaws start at 2". So i used the small expander jaws and went as far as i could, but needed a little more. But the big expander jaws wouldn't fit. There is no overlap on the sizes. If the small went up to 2 1/8" it would work fine to step up to the next jaws and finish. I ended up putting some washers between the jaws and the back plate to get them to expand more. Then i was able to switch to the bigger jaws and finish out.
I did **** the expanding cone into the backing plate trying to get to 2" so I could switch to the bigger jaws amd it did deform my bearing a little bit and make an indent in the backing plate but it still works. Just making the smaller jaws go to 2 1/8" would solve any issues since they would overlap the bigger jaws just a bit. Not sure if that's easy for astro to change or not but that would be a huge help when expanding pipe around the 2" ID.
One other issue I ran into, which is no fault of astro at all is my magnetic 52sl light I got when they ran the bogo deal with the wireless charger. I was doing some ball joints the other week and was grinding the rivets off. Well when I knocked the hot rivet out it flew towards my light I had stuck in the wheel well and the hot rivet stuck to the magnet on the light. I started to smell something burning and saw my light smoking. It melted some of the plastic on the light. Not an issue with the light but just something to keep in mind when working. I didnt even think about it until it happened.
A
South El Monte
It's due to us still making the right angle variant under other brands, but the 206 and 216 we never did, so the sales under Astro alone wasn't enough to keep them in production unfortunately.
We solved that maybe 1.5 years ago or so. The small expander was going to something like 1.95" and the next size up was right at 2.0-2.05". So now the small one goes to at least 2.05-2.1".
We've also improved the forging process, the new expanders and dies are really sweet. We'll send you the new assembly, just confirm your address in a PM.
signcrafter
I'm glad to hear that it was fixed. I absolutely love this pipe expander and have used it many times to fix exhausts. Thank you for the great customer service also.
larry4406
Northern Virginia
I had a chance to use the double cut 1/4" shank burrs set 2181 couple weeks back. Worked very well!
Replaced windows on house with brick front. Could not get to the nails on the nailing fin with a cats paw without damaging the brick. Used a rounded end burr in a HF die grinder and in short order all the nail heads were gone and windows came out easy.
Mr.Smoke
Ontario, Canada
Known of the Astro brand for a number of years now but had never purchased anything of theirs until this week. I needed a new blow gun and was tired of buy cheap $15 dollar ones every 6 months or so. I was putting in an order for other items so decided to grab their 4" and 13" guns. Only used them a couple of times so far but they seem to be built well. Far more flow/pressure than my previous ones on the same air system. The rubber tip is nice as well for working close to delicate surfaces. Hopefully they hold up better than the cheap ones I've been dealin with the last number of years.
A
South El Monte
rnscustom
Plympton MA
So I received the 3037 Astro belt sander last night looks good only things I see I don’t like are it doesn’t have a safety on the trigger and no cover over the drive area of the belt , there is a pinch area there with the direction the belt rotates . It works great . What is the best grit for grinding welds as far as cutting and lasting . I used the 36g it came with , cut real well but you can see the big stones do come off . Wondering if the 60g might be a little slower but last longer / a little easier to clean up the scratches . Thanks
blarf
Thanks, it's like a game of whack-a-mole sometimes. We'll submit a request for them to correct.
The listing now says:
Astro Tools 4524 11-Piece Auto Fastener & Molding Removal Tool Set
Brand: Drake Off Road
I wish you guys had a storefront somewhere else. The inaccurate listings are one of many reasons I stopped buying anything from Amazon. I bought the set from tooldiscounter.com, so far so good.
A
South El Monte
We don't have a storefront. We're just the manufacturer. Our warehouse customers can post our items on Amazon, Walmart, Summit Racing, Carid, Zoro, ebay, their own website or any retailer they choose. Which works well for price competition for you guys, but can lead to plenty of places having the wrong or out of date info that we have little control over.
blarf
Perhaps, but you guys link to Amazon (the most problematic of the vendors you've listed) from your site. In this case you're simply linking to the wrong product from your own site.
MoonRise
Recently bought the Astro magnetic spark plug socket set 94404.
Finally had a chance to use them (well, really only one size :lol: ) yesterday.
They work about 9247% :D better than rubber-insert spark plug sockets (all that I previously had used).
Nice polished chrome plating, partial swivel connection to the permanently attached extension (can be disassembled if need be by removing a set screw), some knurling on both the socket OD and the extension shaft for finger grip and spinning by hand, nice strong magnet that holds onto the spark plug nicely.
With spark plugs recessed into the heads (sometimes a LOT), it is SO nice to not have to worry about the socket losing its 'grip' to the spark plug or an extension pulling out of the socket.
So, a BIG :thumbup: to Astro for these. They are NICE. Nice to look at, nice to hold, and nice to use. Made the job go nice and smooth with no issues with/from the tool. Highly recommended. :3gears:
Also used my Astro 3/8" nano ratchet 93808 for this job, short handle version. Again, a quality tool. The attachment from the tool to the extension held on great and released when I pushed the release button just like it should, the polished chrome is nice to look at and to use (nice and smooth on the hands), short handle was plenty of torque for working on spark plugs, the ratchet mechanism was smooth and worked with no issues, the reversing lever was right where my thumb could reach it to easily switch from remove to install to remove to install, the 'nano' size was a bit lighter and easier to maneuver around than a 'full size' 3/8" drive ratchet.
So, a quick shout-out to Astro for making quality tools that make the job/task go more smoothly with no tool-related drama or issues. :rocker:
I said it before but I'll say it again, Astro is on the top of my list of tool choices.
A
South El Monte
Now I know where you get your ideas from ! (Watch the video, read the comments !)
Wheel Bearing Removal Trick
We just have drawings, but it's as good a time as any to to get it into production. Works with a simple ball bearing to be able to rotate freely and not damage the knuckle. A couple sizes, a couple pieces per size. Should be pretty affordable, take a few months for manufacturing and testing though.
Not sure if it would be cost effective, but I would want 3 per set.
