Tool”ish”
Plastikosmd
Regular screwdriver guide for both flat and tip
Reads “ Standard screw driver shop use”
“T.R. 2nd floor NO.1 bldg”
Then the gauges also have sizes listed, 3/8, 5/16 etc
Mintgrun
Kingston, Wa.
That's very cool. First one I have seen. If I had one of those, I'd be tempted to finally go through my wood-handled screwdriver collection and go to work on the tips. Thank you for posting it.
Tom
Ricky Joe
Roanoke, Va.
I’ve never seen one. I like it. If I had it I would swear that one day I would fix all my worn screwdrivers. Twenty years later it would be in a box at the estate sale.
disston
Silver Spring, Md
It does not appear to be a One of a Kind tool. They must have made more. But this may be the only one to survive. I'll be watching to see if anybody else has ever seen this tool.
Certainly a rarity. Good on you for saving it.
P
Plastikosmd
Thk u
It appears well made
I will likely send it along to someone who needs it more than me and can display it with their collection
The two drilled holes are of different diameter
I like the slopes that are cut/filed/punched in to check the tip thickness
Actually, it reads "STANDARD SCREW DRIVERS FOR SHOP USE." I'm not sure how that changes the meaning, or the purpose, if at all, which is still a matter of interpretation to begin with, but it could.
IMO it maybe from a screwdriver factory. Does TR relate to anything?
My guess for "T.R." would be Tool Room. With "2ND FLOOR" implying multiple floors, and "NO. 1 BUILDING" implying multiple buildings, if it's a screwdriver factory, it is a dang big one.
Another possibility is it's a big factory of some other kind and the guide is associated with maintaining the tips of screwdrivers used in the shop and kept in the tool room on the 2nd floor of building No. 1.
Lassen Forge
Man, that brings back memories. Really.
It's a tool room jig to reprofile screwdrivers... or make them from stock if needed.
One of my earlier jobs required each of us to do "tool room" duty on a rotation basis, and one of our duties when we pulled tool room duty was to do things like sharpen bits, regrind & reprofile screwdrivers, etc.. Since most of what we worked with were relics from the 190's and 30's, keeping flathead screwdrivers in shape (so you didn't waller out screw heads) was kinda vital.
Great score!! :thumbup:
P
Plastikosmd
I appreciate the education!
If there is someone local to RI that has to have it, let me know
