2x4's all crooked
seagull369
I'm rebuilding a garage wall due to a rotted base plate and lower part of the wall studs connected to it. Apparently I'm not very good at "eyeing" what a good piece of replacement beam should look like, as what I've been finding at my local home center turns out being warped, twisted, bowed when I try to put it up.
Could anyone help with some tips to finding good pieces? Perhaps there's a certain type I should be asking for or a tool that might help determine a straight piece from a bad one? The 50 year old + studs I pulled out of the wall, although rotted on the bottom, were absolutely dreamy dimensionally in comparison.
JJN
CA
I go for the full stack of lumber and dig. The boards with weight on them typically are straight or straighter. I may find a good straight one and use that as a guide laying it against others and comparing. Keep in mind the ones buried may have more water content so keep them in the shade and install asap. Or, lay them flat in the garage and put weight on them. It does seem like extra work, and it is.
NUTTSGT
Northern Central Ohio
Are you siting down the lumber before you buy it ?
Are you storing them flat on the floor after you get them home ?
Are you storing them inside until used ?
Kaizen
New England
All the previous discarded ones are stacked on top of the new virgin ones. I go right for those and eye them.
DJF3
British Columbia, Canada
If you want to pay the extra money, you could try purchasing from a truss manufacturer. They typically get the best lumber, although there is a premium for it. It's called MSR, or Machine Stress Rated. Very nice to work with.
ItsNemo
Canada
New bundles are opened up pretty much every day, once the bundle is open they slowly twist/warp into their natural shape as they get exposed and dry. So you can pick a straight one at the store and unless you use it same day, it will be warped by the time you go put it up. Just get used to learning how to straighten them as much as you can while building and compensating where you can't. All lumber these days is pretty ****.
seagull369
Thanks for the tips. I bought some really long ones (longer than the length of my extended cab Ranger) at HD, laid them on the garage floor for a week with weights on top and came to find out the dang floor wasn't flat either :lol_hitti The flatness of them isn't the only issue, though. Best way I can describe it is rectangular snake wood.
I'll check out the local lumberyards in my area, and also enquire about MSR and finger jointed studs,,,, thanks for the suggestions. Maybe getting them in shorter sections is better, also (and laying them on a flatter floor, of course). It would be nice if I had a known good piece in hand I could compare all others to (unfortunately I already tossed the rotted ones I had). I rebuilt the garage's gable end with that home depot wood I had and it was just such a struggle. At this point in the game cost isn't much of a concern. I just want something that's not going to keep fighting me.
spudley
Northeast Wisconsin
Old joke at the saw mill. Be careful the wood will crawl away.
We have a big box store called Menards and the joke here is "if you want a perfect circle, buy three 2x4's at Menards".
OP, +2 on a lumber yard rather than a big box, longer lumber normally is straighter, look for tighter end grain, and bowed lumber can be straightened while installing. Stay away from twisted.
Lumber takes the shape of whatever it's laying on so stack your stuff on flat surfaces. When I need straight and true, I'll stack and ratchet strap it together until use.
Git
S Cal
This
I dig through a lot of 2x4's at Lowes to find really good looking ones. Once I get them home, if they are not going to immediately be used, they get clamped together with my Bessey Clamps
budget76
I usually hold them up against the big I-beam that holds up all the racking in the store. at least I can tell if it's straight when I buy it
shopnut
Florida
I am extremely choosy when picking out lumber because the job is so much easier with straight lumber. But sometimes you just have to deal with crooked stuff and this Tweaker bar comes in handy for twisted studs.
https://www.amazon.com/Mayhew-Select-41500-Tweaker-Multi-Use/dp/B0000224U8
Fatboy148
Store them as dry as possible, up off the floor/ground on stickers. Tie all the lumber back together to make a unit with ratchet straps. They will stay as straight as possible till you let them go free.
dogdog
I have something like this but smaller size about 2feet long for twisted lumber and general prying.
https://www.zoro.com/stanley-demoli...king-tool-55-099/i/G1347351/?recommended=true
nadogail
Coronado, CA
When I needed a bunch of really nice studs I bought full bundles of kiln dried branded ones from the big box store. I refused any bundles that had a broken or missing band.
No way would I accept any lumber that had been “cherry picked”. We were building electronic shop work tables.
safnd2021
North dakota
This is exactly what I do
