Small room moisture control tip:
Sevenhills1952
Virginia
My garage has a bathroom/shower then another room I put a washing machine in.
It's a temporary horse tack room but I had moisture problems, mold on leather, etc.
I ordered this small dehumidifier but you're supposed to empty container, instead I drilled/tapped and put a brass hose connector in it, and a hose going to washer drain. I put JB Weld around connector also.
It's been running over a year and works great. Hopefully this idea may help someone. Rooms are insulated 12x12.20210426_162234.jpg20210426_162241.jpg20210426_162252.jpg
Sent from my SM-S205DL using Tapatalk
kbeefy
Harington, Eastern Washington
Nice idea on the drain.
I'm in the process of buying a house with a fallout shelter under the garage the seems to have a moisture issue, I'm going to do the same thing.
Sevenhills1952
Virginia
I have that exact one on my boat and did the same thing to hook it to a drain. Has been working great for 5+ years.
If it ever quits working like mine did a few months ago take it apart. There's a circuit board inside with two bad capacitors (1000ufd @ 16 volts as I remember). The tops were swollen. Replaced them and works again.
Showkey
"MEMBER EMERITUS"
Wausau WI
Ventilation only works if the outside air is less humid and is the desired temperature. Thats very unlikely..........
BestTree
Since 1994 I have been using Damp Rid which is a desiccant flaked chemical that absorbs moisture in rooms. It just takes routine emptying of the bucket(s) about every 2-3 weeks during the warm months and purchasing Refill product in the 42 oz. bag or 7.5 lb. jug (Walmart.com).
niget2002
Josephine, TX
We rented a condo with a dehumidifier in Galveston last week. Worst part was having to empty the bucket twice a day. Would have been nice if they had plumbed it like this
Grogg
Vienna, Ontario, Canada
I have a few of those exact same dehumidifiers, I used to put them inside vehicles to control moisture when I stored them in a rented space with no climate control. Good little mod!
