bargainhuntingking
Curious, what’s the purpose of the offset?
KM, how are you finding all these unicorns?
Facebook vise groups. You should sign up! Those guys would love to see your collection.
Athol 624 (a different Athol 624, or...?)
2.5" (verified) swivel jaw, no other specs
This one is kind of messing with my head.
The pattern of 640-series swivel jaw model numbers would suggest this "should" be a 642-1/2.
Wonder if two digits in the mold typeset were reversed.
ejot...Excellent find! Around 1915, Athol adjusted some of their vise models, and indeed the Athol no.624 was a 2-1/2" swivel jaw, swivel base vise. In the early 1920's, Athol changed some of their model numbers again, which remained the same into the 1970's.
Since the casting on the vise reads "Athol Mach. Co." this vise can be dated from (1915-1921). In 1921, the Athol Machine Co. became the Athol Machine & Foundry Co.
I thinks going forward we should simply refer to Fierljeppen as the Professor.![]()
I purchased the broken Athol 624. What Ejot's photos didn't show was that the pivot pin on the rear jaw was badly broken as well as the side of the base blown out.
I have successfully repaired the pivot pin and am now working on fabricating a replacement piece to weld into the base. BUT it would be MUCH easier if I could find a base of appropriate size to use, or a broken base of appropriate size/shape to use for the repair.. So if someone has a broken/orphan base to sell, please contact me.
I don't have a photo of the repaired pin, I'll get one when I next work on this project.
The base is roughly 3.5" OD at the top swivel surface, and roughly 1" high.
This is a pretty rare vise, and I'm glad to have it, damaged or not.. The repairs will be essentially not visible without a disassembly of the vise, and even then won't be easily noticed..
PierceA
454Ragtop, take a look at the measuring tape image again. It's a metric and inches tape and unfortunately when I took the photo the tape was twisted a bit and reading the inches side is a bit difficult. The OD of my base at the contact ring is about 3-1/2".
Post a photo of the broken swivel jaw. Maybe there is a fairly simple repair.?
PierceA.
Hey guys, recently found a Leavens Jersey vise no.22 and managed to luckily stumble across a Leavens Jersey vise no.46! Wanted to show you guys the amazing shape this 46 is in with 95% of its original brown japanning still intact after 110+ years. It’s also interesting to see the patent stamped on the static jaw and not the anvil like others. It has 2 1/4” jaws, max opening of 2 1/4”, and weighs 4 lbs.
Ricks' ad cleaned up a bit I hope:
Those Jersey and Colton are some really nice smaller vises. I've got a little more information to add to the Leavens vise, one that's seriously grown on me.
Although the Leavens Mfg. Co. had been around for a while, they finally incorporated in New Jersey on Jan. 7, 1907. The vise is a 1908, Joseph G. Baker patent vise, and one of the witnesses was none other than Philip J. Leavens.
I'm assuming the "Jersey" vise is a takeoff from "New Jersey". Well, by 1912, the Stanley Rule & Level Co. had taken over the Jersey vise line and it is unclear to me what became of the Leaven Mfg. Co.
What's interesting to me is that the Leavens Mfg. Co. never had more than 12 employees during that time span according to the Industrial Directory of New Jersey.
There was a really interesting vise display stand that actually rotated on a wheel. I'm not going to lie, if I find one at an auction, I'm going to dig deep to get it.
Here's a couple of 1910 catalog ads for Dlavallee22's no.46 and no.22 vise. It's a very interesting line of vises that has stood the test of time.
Hollands Mfg vise no.8-1/2
Jaw Width.......2-1/2"
Jaw Opening....3-1/2"
Weight............12 lbs.
Circa..............(1890's-1910) upgraded swivel base throughout the years.
