What Obscure Tools Do You Have?
zippy97
Ontario
Leave it to GJ guys to know the ins and outs of measuring watch spring torque... This been a good read and I hope you guys are right about that mystery tool
. The example in the middle is an actual P.S. Stubbs gauge. Above it, with the wooden handle, is a Disston. Below it is a Chesterman.
Lugz, Hate to rain on your parade on this one, but ironically, I think your Disston is a type of saw set called a Saw Wrest.
http://members.acmenet.net/~con12a/saw set website/wrestsawset.htm
None of the Disston Wire Gauges I’ve seen have handles, and all have the normal selection of sizes, not just 6.
https://archive.org/details/Disston1918Catalog/page/n15/mode/1up
Here are a bunch from a 1909 Marples catalog, where they just call them saw sets.
davethorik
Norka, Ohio
A lot of machinist tools are obscure, relatively speaking. These took the cake. At the time they would have made my life a lot easier for a lot of measurements, mostly no more tearing down depth mics every 5 min to take a new measurement.
Finally found a deal on a used set from a machinist I knew.
The 527 series dial depth gage 0-12", with fine adjustment. Used the piss out of them. They are super smooth and repeatable, just like the Mitutoyo dial calipers they are based on. (pic from Amazon) i dont use them as much now, but i am never getting rid of them.
ed4banger
Virginia
Old hammer...The ******......
J.A.F.E.
Formerly Area 49 now Area 52
Here's one that's a little more unusual. It's a cigar box hammer. Used to open the old wooden cigar boxes and renail them again.
The company was owned by a relative of my maternal grandfather who worked for them for a while. It is probably close to 100 years old.
J.A.F.E.
Wheel bearing torque wrench for old spindle style tapered roller bearings. When this was made all brakes were drum brakes so it dates to the 60's or before.
simnil
Sweden
As far as I know it's the only one ever made, so cracking this one might bring some bragging rights :)
I'll give the answer if someone is curious.
In the case where you have a large bundle of hydraulic hoses and you want to identify which one is used for a specific function you clamp the tool to each hose in turn and activate the function. When clamped to a hose that gets pressurized the needle on the gauge will twitch. It wont give the pressure in the hose but it will indicate a change in pressure.
The tool consists of a small hydraulic cylinder with a small piston that is opposed to the clamping screw. So when tightening the clamp the hose gets squeezed between the piston and the clamping screw and when pressurized the hose will want to expand thus resulting in a pressure increase in the small cylinder that registers on the gauge.
People not concerned with safety can just use a hand to feel the hoses but people has lost their life, and more people has lost limbs, from hydraulic oil poisoning "*********" pressurized hoses.
rlitman
Long Island
Interesting. I wonder if a belt tension gauge would serve the same purpose.
Forgottonia
edge of Forgottonia
Not sure how obscure this is, but it's a cute little thing. Bought it at an antique shop a few years back. If there were ever markings on it, they are not visible anymore.
Nice pocket wrench. Hard to say who made it. The first of its kind, with the milled handle for the dynamic jaw "way", was a Billings, patented (212,298) here in the US in 1879, but they were soon copied and improved etc. The British were fond of them, too. They were still being stocked in Norton, B.S.A., and other motorcycle kits as late as WWII. Some of them are open shaft, others closed. If I remember where I saw your particular design with the through shaft like that I will post it.
