Teter09
I've been researching and searching for a light duty mill for a while now. I'm limited in space so those devout 'get a Bridgeport' comments don't really apply as I can't house one. I'd basically resigned myself to a Sieg X3 or eqiuvalent when I saw this pop up on Craigslist. I realize some folks will instantly tell me this isn't a mill, except for my lighter material purposes, it will work just fine. Also, the ways are dovetailed and not the simple sit in style so they won't move on me when milling. Then again, the heaviest thing I'd be doing is 1/4 thick annealed steel. I'm confident it will work for me.
Couple pics before I got it home. It is about 6 feet tall to the highest point on the pulley cover when closed, and weighs about 900 pounds.
View media item 45277
View media item 45276
Trying to find information about this machine just flat out *****. There are few other people who have one (at least who have posted pictures or comments about them online) and those who have, they have the Sheldon-Vernon version which came about in the 50's. The machine tag below shows I have the true blue Vernon machine but I've been unable to figure out the year of manufacture. There was a single document over on vintage machinery, but its a sales pamphlet and not a manual unfortunately. There is a pretty decent write up about the Sheldon version over on http://www.lathes.co.uk/vernon/ but certain things are very different between the two as I've found out in the tear down for cleaning.
View media item 45278
In order to transport it, I had to take the head portion off and luckily at a few hundred pounds, I could get a friend to help me lift it on to my bench to tear it down. The gentleman I got it from hadn't really been using it, and things were sticking all over, which suggested I needed to tear it down to relube and fix any issues.
View media item 45279
Motor was slightly gritty on the outside but was NOTHING compared to the inside.
View media item 45281
After removing the power switch, you can see a couple of the different colors. This machine had quite a few all over it. The column seemed to have more of a mint green in spots, where as under the power switch you can see the avocado green? The machine grey color had been thrown on at some point with no regard to properly taping off or disassembly, since the dials were slopped on, the table in the T slots and even the belts had been painted.
View media item 45280
