Cutting up large tanks!
PCustoms
VT
Cut up an old oil tank with a carbide recipe blade, like warm butter with a hot knife.
Cut up another one with metal cutting recipe blades, still like warmish butter. Save money and get a 10pk of standard metal cutting blades.
redmondjp
Redmond, WA
What if one had gas in it?
You would have to also have oxygen in the tank at the right level for there to be any combustion. And old gas has long since lost its volatiles (meaning you can hold a match to it and it may not even light) unless it was in a completely sealed container. It's not that big of a danger as people make it out to be.
As stated in another post - fill it with water to displace any vapor, and bonus, the water will also keep the cutting blade cooler.
lis2323
Think I would rent a backhoe for a day and use the bucket to pound on them....Shouldn't take much to beat them down pretty flat.
That would kinda work. Still need to remove end caps to get reasonably flat though.
66cj225
NH
+1 American Locomotive
You still don't know the vapor content of the sludge.
neophyte
Pennsylvannia
To avoid spark issues, Nibblers and strip shears are routinely used for cutting up old fuel tanks.
The only major issue is cost.
The Nibblers and shears you might want to use, can easily cost $1000-$2000.
A reciprocating Saw or decent jigsaw would be the next best option, but there’s more of a chance of sparks.
An Angle Grinder with cutting blades, whether bonded abrasive or “permanent” diamond, would be the next option, but there would be a lot of sparks.
65ranchero
Danville, VT left NJ forever
Reciprocating saw as others have mentioned I would think that any gasoline is past expiration /leaked out.
Not wanting to hijack the thread but that reminds me of pulling the tank
Did a UST 1000G heating oil tank that I had abandoned at my other house on the 80's, At the time it was legal to cut a big hole in the top and fill with sand and leave it buried.
My wife found about grants to pull the tank and remediate the soil so we had it pulled and ground was test bored and such the grant saved us 20K
matt_i
SE Michigan
How much less do you get in scrap if you don't cut them up?
I'd look at it as an hourly cost of your time. IOW I'd see about the scrap yard taking them as-is, they handle ungainly metal objects on a daily basis.
If you spend 5 hours of time and $50 in blades to gain another $100 in scrap you got paid about $10/hr....my numbers are a pure guess so put in your own to check.
DocsMachine
Friend of mine was killed cutting up "old, empty" oil tanks.
I filled a 500-gallon fuel-oil tank with water. Hadn't been used in at least a decade by that point, and had been stored with the bungs open. As I was cutting it, the gunk floating on the water caught fire several times.
Be careful.
Doc.
bargainhuntingking
The Amazing Pacific Northwest
Be careful.
Doc.
Was that in Bakersfield about 10 years ago? I used to drive by the site where a similar fatality happen. Enormous tension on those big tanks. My condolences.
DocsMachine
No, Alaska 23 years ago. Left behind two kids like 5 and 7, and no mother. Always wondered what happened to them.
Doc.
SeisMec
Beryl, Utah
Doc.
Was the guy named Ron DeVilbis. (Not sure I've spelled the last name correctly.) If so, I worked with him in California.
lis2323
Are the scrapper trucks circling your block?
I haven’t had my bin picked up lately but last time steel was only a round one cent a pound. $20 /ton
macgee
Sepulveda Pass, CA
I know this is post problem as OP got it done but what about shooting fire extinguisher foam into a questionable tank, coating the inside walls before cutting? That would seem way easier than filling 500 gallons of water?
The Cobbler
yeah, a plasma would have made short work of that . saw a guy weld up a gas tank once,I thought he was going sideways on us, had his truck exhaust running into his shop with a hose... it was going into the gas tank to fill it with C/O ( no oxygen)
there he was brazing up a leak with an open flame !
Lwel9226
So Oregon
I have done that, works good.... You can use any internal combustion engine... Lawn mower or whatever you have handy....
LynnW
DocsMachine
If you have a Kegerator, you can use CO2, too. I did that once to TIG up a car gas tank. (Emptied, rinsed, blown dry, left to sit a week inside with an open cap, dumped a ton of CO2 from a 20-pound tank in there, left a small regulated hose running while I rand the bead. No issues.)
On the other hand, I know a guy that was literally blown through the wall of his shop welding up an aluminum fuel tank- he survived. Pic of the tank showed it peeled open like a banana.
Doc.
Toxictom
Anchorage, AK
Around here I believe you just have to cut a big hole in the ends and not remove the entire end.
I once worked with a guy who was blown to smithereens welding on a tank. I'd seen him working on the tank about an hour before it happened and he asked me about the alignment of a piece he was welding onto the tank. As a previous poster mentioned we've had several of these type accidents in Alaska.
will335i
IL
For better or worse, Alaska is still pretty much the wild west. Things are lax enough you can do as you please but you damn well better know what you are doing.
Al Borland
FYI you can inert the tank with dry ice. Tape over any holes except one at the top. Once a visible "Fog" is coming out the top hole you left open, all the air (oxygen) has been pushed out. CO2 is denser than air, and will push the air out the top. A little water with the dry ice speeds the inerting process.
marinusdees
Edgewood, Washington
This is the way they "inert" tanks before they can be transported on the road.
tarbellb
Oregon
Very cool, some Bill Nye stuff there
