Small U-channel made from metal or plastic
Ralf11
Where would be the easiest place to find a run about 8 ft. long of U channel material?
I'm looking for the cross-sectional sizes to be about 3" and I need a flange on it so I can screw it to a wall.
Thanks!
R
Ralf11
Thx - will that hold up on an exterior surface with sun & rain?
4xdog
Santa Fe, NM
How about something like extra-low-profile strut channel?
https://www.mcmaster.com/strut-channel/extra-low-profile-strut-channel/
Edit: I missed your 3-inch width. That's kind of wide for any strut channel -- even standard size. bob15 is on the right track, I'd say, thinking of raceway.
It wouldn't be too hard to have some sheet metal bent into your channel either.
jubilee
Colorado
I make my plastic/vinyl angle, channel, and ect. out of plastic/vinyl fence posts. Straight edge and rotozip, small skill saw, table saw, or whatever will cut it.
Throughfaith323
Definitely using this idea one day!
If you decide on steel, local steel supply places are far cheaper than big box stores/other.
quickfarms
Southern California
I would either bend it out of 16 gauge or take a 4 foot piece of 1/8” wall box tubing and cut it so you have two pieces.
A worm drive skill saw with a metal cutting blade will easily cut it, just use the guide attachment
This is my favorite blade
R
Ralf11
still spinning my wheels on this - metal won't work
- what are the things called that HVAC guys use to hide piping runs on the outside of a house (like for ductless heat exchangers)?
This is to cover a run of pex used on the outside of a house, which needs to be shielded from sun light.
R
Ralf11
It is already installed - so I need something I can put over it. something U shaped with a flange would be perfect... 2" x 2" inside
Youngandfree
VA
Plastic downspout
NUTTSGT
Northern Central Ohio
You could cut the back side out of the conduit and use conduit straps to hold it on.
Jim_No_Garage
Millington NJ
When I was in the HVAC business for 1 weekend they used metal downspouts to cover the line sets as they ran them up the side of the house. They had a trick to snip on both sides of the seam on the back and then "peel" the strip down the entire length of the downspout. That avoided the hundreds of "meat hooks" you would have left if you cut it with tin snips.
Ak Jim
Interior AK
You could just put the sections of pipe insulation over the PEX to temporarily protect it while you figure out a more long term solution.
flippin
Montreal - Ottawa
As said by others, sheetmetal shop could make whatever profile you wanted in an outdoor grade prepainted steel. Would be both inexpensive and much more durable than plastic.
