metal 2x4
mcmaster
I make my plastic/vinyl angle, channel, and ect. out of plastic/vinyl fence posts. Straight edge and rotozip, small skill saw, table saw, or whatever will cut it.
Plastic downspoutstill spinning my wheels on this - metal won't work
- what are the things called that HVAC guys use to hide piping runs on the outside of a house (like for ductless heat exchangers)?
This is to cover a run of pex used on the outside of a house, which needs to be shielded from sun light.
You could cut the back side out of the conduit and use conduit straps to hold it on.It is already installed - so I need something I can put over it. something U shaped with a flange would be perfect... 2" x 2" inside
You could cut the back side out of the conduit ...
You could use a hand saw but I would use a circular saw or jig saw.hours of painstaking work with a hand saw is exactly what I want to avoid
