Hi,
Hopefully I'm posting this in correct location.
I have the Tractor fever again. I'm surrounded by corn, and Tractors are plentiful. I live in rural area on 5 acres now and if He gives me enough time, I'll settle on 25 in Wyoming.
Like most things, I look around and ask myself: Do I really need a tractor? When I consider 5 acres, I say "sometimes", but
with 25AC it's a definite yes. I made of list of jobs I envision using for: General Lifting - dirt, engines, Mowing the 25 AC, Fence Post digging, snow removal.
I want a Diesel as well as the availability of parts should I need them. Neighbor in Wyoming says 4WD is a must. Farmer has all Green and says stay away from Orange. One thing I don't want to do is buy something that I'll wish I'd gotten this or that. I was hoping to invest no more than 10K.
So far I've seen the following objects:
JD 2440, JD 143 Loader, 52HP, Single Remote, 2700 hours, $9500
JD 3020, JD 46A loader, 70HP, $7900
JD 2355N, 1992, 2WD, $5K. Hours unknown due to smeared glass on Hour Meter according to Local Seller. Does not have a Loader, but "thought" maybe I could retrofit it with a Loader (245,175) since I've seen pics of 2355N's with loaders.
I'm open to any suggestions/advice/lessons learned. Some questions I have are:
Is there a source that will tell me which implements will fit on which tractors?
I'm not opposed to buying something and adding things like a Cab, Loader, IF I knew the "possible" upgrades I could do. Or should I buy one with Cab/Loader already intact?
Thanks.
