Today I learned something about Channellocks handles.
dwasifar
I recently wrote to Channellock with this question:
Here is a curiosity question. Genuine Channellock groove-joint plier handles have a little inward curve at the ends. Some competitors also have this handle shape (Craftsman, Crescent, Harbor Freight, Irwin), and some do not (Milwaukee, Kobalt, Husky, Stanley FatMax).
What's the reason for that curve? Is it to bring the ends of the handles closer together so that more force can be applied without an uncomfortably wide grip? Or is there some other function to that shape?
Just curious. Since you guys invented this design, I figured you'd be the ones to ask.
Today they replied:
Thank you for your message and question.
This curve was originally added to the handle for pipe reaming purposes. Our first models did not have the grips applied to them. Many plumbers remove the grips today from the ends of the pliers so the steel is exposed for this purpose. Depending on the user, the curve could add additional comfort but the original intent was for the reaming application.
I hope this helps!
Thank you for your support!
Channellock
So now I know. I imagine anyone here who's a plumber already knew this, but not being a plumber, I didn't. I'm trying to picture how that curved end gets used as a reamer; I imagine you set the pliers wide, so that the handles are close together, and insert both ends into the pipe together. Right?
Obviously those pliers that have big beefy handle grips like Irwin cannot be used this way:
Looks like Milwaukee has their own idea about this; their pliers have exposed pointy ends which might be intended as reamers:
milwaukee-all-trades-tongue-groove-pliers-48-22-6330-48-22-6208-48-22-6210-e1_600.jpg
vjquan
Since you didn't post a pic of the Channellocks, you made me go out to the garage for a look. Interesting, thanks for sharing.
Ohmthis
Outside of Louisville KY
I’m an electrician and we would purposely trim the end of the handles to look like the Milwaukee. When cutting conduit, we would then slide the handle ends into the pipe and ream the burr off. I ended up getting and using a reaming tool that went on the shaft of a screwdriver.
D
dwasifar
Can you share a link to that reamer? I'm not an electrician, but I live in an area where conduit is required for residential applications, so I sometimes have to cut and bend conduit. The little flip-out reamers on the conduit cutters don't really do a very good job.
rlitman
Long Island
Hope this image straight from Milwaukee helps:
I could swear I've seen pliers like that with the ends having a more angular profile to ream more aggressively.
edit: Maybe it's just the outside of linesman pliers jaws I'm thinking of...
Yup, been doing it for years with my non-plastic handled craftsman. Forget if I learned it from an electrician or pipe fitter, but suspect someone in the trades at my first job, oh those many years ago.
JRC3
Southwestern OH
Nah, the ends are curved so they properly pinch your fingers when the tool slips off while being used for a task it wasn't really meant for.
Don't even act like you've never done it. LOL
Ilikeike
Northern Ca.
I got this one a couple of decades ago, it slides on the a set screw lock on this old Vanadin driver. I googled a bit and can't find this type a reamer anymore, just the dedicated ones from Klein or Wiha
rlitman
Long Island
I
Here you go:
Kscardsfan
The Little Apple
I was fond of these for reaming and installing conduit
Ohmthis
