Which Pressure washer
jasvance
Rome, GA
Trying to decide on a Champion model 100382 2600 psi 2.2 gpm or the Simpson Megashot Model # MS60773-S 2800 psi 2.3 gpm? Please comment any info that may help me decide. Thank you!
J
jasvance
Rome, GA
Here is a link to the Simpson at Lowes. https://m.lowes.com/pd/SIMPSON-MegaShot-2800-PSI-2-3-GPM-Cold-Water-Gas-Pressure-Washer-with-Honda-Engine-CARB/1000507359[/url]
J
jasvance
Rome, GA
And here is the Champion at Lowes. https://m.lowes.com/pd/Champion-Power-Equipment-2600-PSI-2-2-GPM-Cold-Water-Gas-Pressure-Washer-CARB/1000259101[/url]
bmxdukie
Ontario, Canada
Buy the one that you can get parts or service on.. those cheap models usually don't have much of an unloaded. And when they unload get hot fast.. burning valves and seals.
tarmy
Nor Cal
As many will suggest...which is not really your question...get one with a Honda engine...you will not regret it...
metalmagpie
Seattle
I have a different proposal: buy the cheapest used electric pressure washer you can find. In my case, it was a tiny yellow Karcher for $15. Its hose had a leak in it. I found one someone was scrapping and got their hose, free. I have been using this little pressure washer for about 15 years now. For a buck a year anyone could afford this.
If I really need a big monster, I borrow or rent one. But this little guy does everything I need.
metalmagpie
jonshonda
Wisconsin
I'll tell you what I do and don't like about mine (don't remember the brand, but is really applies to all washers I guess). I hate the hose that came with it, too stiff and a pain to manage, so I bought an aftermarket flexzilla hose which is much easier to handle and roll up. Not of fan of the wand management either, it seems like every time I move the washer back into it's storage spot the wand falls out of the holder and I end up cussing.
I do like that is has large wheels that roll well over stuff, and that the wand, hose, and tip storage is up high on the handle as I am 6'2" and not a fan of bending over.
SJay3660
On 30 Acres in Saginaw/Midland/Bay City Area
I got a Ryobi electric pressure washer new for 40$. I then added a 50' hose from Amazon. Works just fine. Use it to wash the cars, not as many GPM as you are looking at, but I just plug it in and it works. Don't care if I need to buy a new one every year at that price.
Hot shot
Virginia
Determine what you will be using it for most of the time
Then make the decision, gas or electric, psi and go from there
1320stang
Edmond, OK
Do not let anyone use it for a car wash fundraiser. I let the band use mine for 2 years in a row (me operating) and as I'm loading it the 2nd year, the pump was puking grey ooze. I got a total of maybe 14 hours out of it and 12 was the two car washes.
cdestuck
Altoona, Pa
Your better machines, especially the pumps are the ones that have a horizontal shaft engine and the pump is mounted beside the engine rather than below it.
Chapter21
North Carolina
The pumps are weak on the consumer models but also stupid easy to replace.
I always think it's funny how many pressure washer engines with a cart there are for sale on craigslist...engine runs, no pump!
If it is direct drive and the pump never requires an oil change, expect a very short life. They are cheap/easy to replace if you can find the right one that fits your machine...I've noticed they like to use a lot of oddball sizes on the crankshaft for some reason.
Much like an air compressor, if it has serviceable oil, and is belt drive, it will probably last a long long time. But very expensive.
bmxdukie
Ontario, Canada
Buy a Dynablast or Kodiak.. direct drive or belt drive 5 year warranty on the pump.
They use honda engines, general (interpump) pumps. And if you go heated becket burners.
Nthill93
Long Island, NY
What are you using it for? Washing cars get an electric. Small patio and house every couple years get electric or hire someone. Looking to make money with it get a bigger washer. I have a Simpson alh3225 3200psi 2.5 gpm and works good for patios and houses but the low gpm makes doing big patios a pain. I just upgraded to a 4400 psi 4 gpm unit. Makes a huge difference
Bretny
Dutchess county NY
Forget service on Honda motors. Anybody who services Hondas will not work on a pressure washer!
What's there to service? An oil change, air filter, spark plug and a carb change..decide that the thing is probably going in the garbage.
junkyardwarrior
don't discount the Yamaha pressure washers. I bought a PW3028. 3000 psi 2.8 GPM. Expensive yes. Worth every single penny. Parts readily available, not that I needed any. I bought a quart of oil from the dealer for $9. Big whoop. Air filter is foam, I clean it and reinstall after it dries out. Spark plug can get anywhere. Didn't need a valve cover gasket for valve adjustment. I really like this washer. When it unloads it goes back to idle, saves a lot of fuel-and best of all, much quieter at idle rather than running 3500 RPM all the time like most of them do. Didn't know I'd use it much but I have used the poo out of it in the 6 years I've owned it. House, driveway, deck, shop, floors, mower, tractor, you name it. Been a good investment. One thing I really like about it is that the handlebar folds down so it's flat on top, so in the winter time when it's winterized and out of use, I fold the handle down and I can easily stack stuff on top of it. Tires are non-pneumatic, no flats. They roll perfectly easy. The ONLY complaint is that the hose is stiff. Easy fix-have a hydraulic shop make up a hose for you out of rubber hydraulic hose. Not real expensive but quite a bit more flexible-and tough.
Doc1976
Mesa, AZ
This is because no one uses a pump lubricant after use. Briggs and stratton pump saver is what I use after every use of the sprayer. Works like a charm.
Chapter21
North Carolina
Honestly Honda small engines are ****. Overcomplicated and overpriced, hard to work on, expensive parts. The only small honda engine I ever owned was on a pressure washer, I've never had a bigger POS engine. Even when nearly new, it refused to start WARM. And was far noisier than a $150 lawnmower. And for the most part unrepairable. Even the crankshaft was some stupid spline output, so it couldn't be used on anything else.
It was fun to put it out of it's misery with my .44 mag. I'd take a Honda CLONE over an actual Honda any day.
If the pump does not have it's own oil reservoir, you are fooling yourself. The entire time you use it the only thing lubricating the pump is water. And since cheap ones have bad bypass valves, often really hot water. Just like air compressors, they come in oiled and oilless...one lasts a whole lot longer. Cheap homeowner non oiled versions are not meant to last more than about 50 hours, because that would take most homeowners 10+ years to accumulate.
What you suggest is kind of like running a 2 stroke engine without oil, but then putting some oil in it before you put it away. That's not going to help, you already wore it out.
Doc1976
Mesa, AZ
The pump saver works as an antifreeze and a lubricant to keep internal parts from rusting and corroding after use. There will be water left in the pump after use that if left alone will rust and or corrode the internal parts. Take a pump apart after maybe a year that hasn't used the saver and compare it to one that has and you will see the benefit.
Doc1976
Mesa, AZ
I should probably add that the pump saver is most beneficial for those of us who don't use their machines every day. If the unit may see a few weeks or more between uses, it will absolutely extend the life of the pump.
Chapter21
North Carolina
It is definitely a good idea if you're putting it away for the winter and it might freeze. Freeze is death if you don't flush out all the water. I've ruined an electric one that way. But I don't think it's really lubricating anything...
I thought it was marketed as a once a year sort of thing, but I could be wrong.
