Hobby_Man, two things you have mentioned interest me. The first is that your slab temp was/is 80 degrees. The second is that you mention it’s normally warmer there, but it’s been raining “every day.” When you started this thread, was it the first time in days or weeks that you had used your system in cooling mode? Reason I ask is that when people heat their buildings using in-slab heating, they don’t use slab temperatures nearly that warm, and they are comfortable. I suspect your slab is heat-soaked, and that makes the air temperature you measure feel warmer than it would in the absence of a hot slab. Following the advice others have given regarding letting the system run for a couple days shooting for inside temps in mid to upper 70’s and measuring slab temperature each day may shed some light on this. It’s pretty clear that your unsealed, uninsulated steel days aren’t helping the situation. Are they in direct sun? Does any part of your building ever get any shade from trees, or is it full sun all day long?
