plc268
Yea, the one on my Gen 1 was glued on. Heat might help, but I just used more force to twist it off. the vacuum hose is pretty durable, and eventually the glue will give.
littlelebowski
VA
I'm having issues with an M12 inflator that I was gifted (no receipt). I've tried screwing it onto a truck tire several times, but it won't read the existing tire pressure. I've not found a button to press to bring this about; am I missing something or do I have a bad unit? The tires in question certainly have plenty of pressure.
Black300zx
Elkton, Md
Did you hit the power button? I just grabbed mine, put a battery in, hit the power button (not the inflate button), and screwed it onto my tire. With the power on, as soon as I screwed it on all the way the display read the tire pressure
ptgarcia
Alta Loma, CA
littlelebowski
VA
Yup, tried that with differing batteries and both the tires on my truck and my wife’s SUV. It’s disappointing. Would going to a Milwaukee warranty center be better than calling Milwaukee?
javyLSU
New Haven, CT
Just as I feared, buying some Packout leads to… buying more Packout. I have a Toyota FJ Cruiser, and whenever we take this vehicle to a store there’s never a great place to put the items because the back is just a giant unpartitioned area. So, Packout to the rescue.
I just finished installing the mounting plates and moving everything over - I still have to finish building my first aid kit on top, but I was able to fit all of my winching/recovery stuff in the middle tool box, and even found a place for my old Craftsman USA set that I had retired. The crate is the perfect size for most trips to the store… And if I ever need the space for larger items, it can all be removed in 5 seconds. Very happy with the way this turned out.
MINIz guy
Philly
What's everyone's thoughts on the M12 RA die grinder vs. straight die grinder? Planning on using it to strip paint, rust and prep metal for welding. Is there a situation where the RA is more versatile?
PIP Hardware has the M12 straight die grinder for $125 which is the cheapest I've seen around. I could do the Home Depot hack for the M12 RA die grinder for $131ish.
darkzero
SoCal
For what you described I would go with the RA, it's much more suited for those tasks IMO & is how I use mine.
I also have the straight but I use it mainly with carbide burrs, grinding stones, & cut off wheels (light duty cutting). The straight is too awkward to use with sanding & prep discs IMO.
I do also use carbide burrs with the RA depending on the situation. I've seen some people use cut off discs with the RA but that orientation seems weird to me unless there's some odd situation where I need to (never have though).
This is exactly how I used all my pneumatic die grinders when I used them. Haven't touched them since I got the MW die grinders.
Bighead38
Rockland County NY
I have to agree with the above even though I don’t have the Milwaukee die grinders. I use die grinders a ton in the garage. The straight one has a cutting wheel on it 99% of the time. The RA one gets everything else like rolocs, stones, carbides, and wire wheels.
MINIz guy
Philly
Awesome, thanks guys! I see the need for the straight one but the RA one will serve me for 99% of the stuff in my immediate future
danny_barkley
FL
I have a bunch of Milwaukee M18 and M12 stuff. I need to buy a Dewalt 20v tool, a nailer. Do you folks know of any adapters for Milwaukee M18 batteries that work well?
PelicanPines
One issue with an adapter... the company that makes the adapter will NOT warranty your tools if the adapter blows up the tool or battery. So is it really a benefit to have an adapter when you are taking a risk of bricking your battery or melting your tool?
I have Milwaukee tools and Dewalt tools... I get the best tool for the task. Like you did with the nailer. I have more than twice as many Milwaukee batteries/tools as Dewalt...
Ryan
Administrator
Texas/Hawaii
I've been using your standard M18 fuel hammer drill & driver set at home for years... and other than mediocre chuck on the drill, I've been happy with them.
So on that experience, when I got to Hawaii, I bought this cheap set:
Man... I should have just spent the money and got higher end set like I have at home. The chuck on the drill is not great, the driver is just okay... and both feel like they were made for the home DIY guy and not some guy that is gonna work them out consistently. I can't see either lasting all that long with the way I use them.
My own fault as I'm sure they are fine for most, but... I should have either spent the big money on Fuel or gone m12 for lighter applications.
Bighead38
Rockland County NY
Yeah fuel is the way to go. I convinced work to start using Milwaukee but they aren’t getting fuel stuff. It’s better than what they had but not what it should be and won’t last as long.
danny_barkley
FL
Chucks seem to be throwaway items on them...
RedneckWelder
The Ghetto Kingdom of Methlandia
to me those older tools are what gave Milwaukee a mediocre reputation that they had for cordless tools before the Fuel generation tools came out.
never rest
USA
What do Milwaukee deals look like around the holidays? I just got into M12 with an impact driver, and I'd like to get a 1/2" stubby. Do batteries or tools come down much on sale?
Well I looked for some past sales, and it does seem like there are some nice deals to be had. Think I'll wait for a bit and see what comes up.
JettaGetUpandGo
Pewaukee, WI
There is an opportunity to register for 2021 and it says a date has not yet been determined. I am assuming that they are going to do another Pipeline/online only event again rather than the full NPS event. Events like NPS take so long to plan they probably made the decision to be safe rather than sorry.
Who knows, maybe they will surprise us with NPS in the fall. I feel the NPS would get better coverage and more attention than the Pipeline videos did.
mobiledynamics
Gotham City
I'm good either way - pipeline or NPS. Just wanted to see what new goodies may be coming out.
Although I'm pretty content with the -collection- I have already...which is too many to boot ;-)
Keep
Oshawa, Ontario
Dammit. I just bought my first red stuff a couple months ago, only the 12v stuff as I have a bunch of Bosch in the 18v. I seen a video of some dude using the 12v 1/4 ratchet...and well that was the start of the "red stuff"
Of course HD up here is now having "Milwaukee Mega Month" with a bunch of great deals......damn this place!!!!
Anyone have the 12v Oscillating Multi-Tool? If so, how do you like it?
Nthill93
Long Island, NY
The fuel is great the non fuel is garbage
Keep
Oshawa, Ontario
Ahhhh got ya. I think the one in the offer is the non-fuel. Buy 2 2ah batteries get a free tool. That is one of the options.
Nthill93
Long Island, NY
Had the non fuel it overheats on the easiest of cutting or sanding. Wood plastic pvc anything you tried to cut. I constantly had to pull the battery out to reset it. Burnt it up got a new one same issue burnt that one up and got another one and sheared the teeth off the head. Seemed to work best with the xc 3.0 battery fully charged. The fuel is a beast will cut anything and I’ve yet to break it. Overheated a few times but not anywhere close to the non fuel.
Odd-job
M12 spot blower. Must have missed this one coming out.
ThatSickRip
I like my Fuel 12v OMT OK, but to be honest, I have not found as many uses for it as I thought I would.
Mine was great for our kitchen remodel: cutting out old backsplash, cutting out baseboard and shoe mold for new floor cabinets, and used it for a bunch of outlet cutouts from the new island to relocating wall outlets
GeoBruin
I feel like an OMT is something you find more uses for the more you use it. Also, blades matter. If you use crappy blades or dull blades, you might not think it's doing what it's supposed to do (and it isn't!) but with a good sharp blade, and used properly, they can do things other tools cant.
dacan23
RI
Finally got through to customer support regarding my dying 12.0. Many days of no call back or their phone system errors. Don't know why you cant use e-service for them, they are only sending a shipping label, nothing special like the bad 9.0s.
Also spoke to a product tech regarding the leaky PS tank for the sprayer. He said many of the first batch leaked, the concrete or water supply tanks didn't have an issue. Again not an e-service eligible item, it needs to be directed to a special group, and I think they just send a new tank, they don't want used tanks sent back. I had returned the spare tank to HD that also leaked. I have a whole second kit I just got, but its the fresh manufactured batch so not expected to leak.
