I don't need a ratchet, extensions, etc, just looking for a socket set like this to use with ratcheting wrenches:
Any other options besides tool truck brands?
If you need it to have retention that's an easy fix. You just need to make a quick custom tool.@Steve_P
Those wont work very well with regular ratcheting wrenches as there is no retention.
this is quite smart, i like itIf you need it to have retention that's an easy fix. You just need to make a quick custom tool.
Buy or grab a spare 3/8" square drive female to 1/4" male square drive socket adapter. Preferably one that reduces immediately to 1/4" square instead of tapering to 1/4" square at the 1/4" male end. Then use a lathe, hacksaw, angle grinder cutoff wheel, Dremel, etc. to cut off the 1/4" square drive male end plus a small amount of the larger diameter socket body. Essentially you cut off what in the end looks like a coin with a 1/4" square drive sticking out the center of one side (pic1). Now you have a small adapter that fits into the top of the Oreilly sockets and has ball detent engagement (pic2). Now, after you put an Oreilly socket into a ratchet wrench, you just press your custom small adapter into the top of the Oreilly socket and it will lock the socket firmly to the ratchet wrench. It works very well (pic3).
Here's the dope on the Astro wrench for use with the nano sockets: https://www.astrotools.com/ratcheting-double-flex-head-wrench-for-nano-sockets.html
No you don't. The 3/8" sockets fit on one end of the wrench and the 1/2" sockets fit on the other.
What size is the hex pattern? I'm curious if these sockets work with the Facom/USAG, Wera, Snapon, etc. 11mm outer hex ratchets.I've got the OEMtools pass thru set. Can be found on Amz as ASIN B01ELYPMSK
Based on the images shown for the OEMtools set, it appears that the size of the hex increases with the size of the socket. It isn't a constant hex size for the socket range like most other sets.What size is the hex pattern? I'm curious if these sockets work with the Facom/USAG, Wera, Snapon, etc. 11mm outer hex ratchets.
I have these in both sae and metric. I did buy the ratchet that goes with them as well. the ratchet has an adaptor that works with reg sockets. you can also use these sockets with a standard ratchet. I use them with my HF thin ratchet. haven't tried them with a wrench. they are very short and fit in some tight spots.I don't need a ratchet, extensions, etc, just looking for a socket set like this to use with ratcheting wrenches:
