low profile sockets to use with ratcheting wrench
Tools4Me
I actually use the Pricess Auto sets (SAE and metric) that the OP posted for my 1/4" equivalent ratchet wrench sockets.
I then use the Harbor Freight set for my 3/8" drive equivalent sockets. I threw away all the sockets smaller than 1/2" and 12mm, because they are way too bulky to be useful and the smaller Princess Auto sockets cover that range already.
For 1/2" drive equivalent sizes I use a no longer made Bostitch pass through set that goes up to I think 1-1/4" and 27mm if I remember correctly.
Tools4Me
Oops, I said Princess Auto for the 1/4" set in my previous post. I meant Oreilly Auto.
Tools4Me
@Steve_P
Those wont work very well with regular ratcheting wrenches as there is no retention.
If you need it to have retention that's an easy fix. You just need to make a quick custom tool.
Buy or grab a spare 3/8" square drive female to 1/4" male square drive socket adapter. Preferably one that reduces immediately to 1/4" square instead of tapering to 1/4" square at the 1/4" male end. Then use a lathe, hacksaw, angle grinder cutoff wheel, Dremel, etc. to cut off the 1/4" square drive male end plus a small amount of the larger diameter socket body. Essentially you cut off what in the end looks like a coin with a 1/4" square drive sticking out the center of one side (pic1). Now you have a small adapter that fits into the top of the Oreilly sockets and has ball detent engagement (pic2). Now, after you put an Oreilly socket into a ratchet wrench, you just press your custom small adapter into the top of the Oreilly socket and it will lock the socket firmly to the ratchet wrench. It works very well (pic3).
budget76
this is quite smart, i like it
dnschmidt
Phoenix, AZ
Astro has already solved this problem for you. They make a special ratcheting wrench that takes their Nano Impact sockets (one side takes the 3/8" versions and the other the 1/2" versions) it has a retaining ring that clips onto the tiny grooves in the hex part of the sockets. Why reinvent the wheel?
rcbk00
+1 on the Astro low profile sockets and the ratcheting wrench they make to go with them. If you don't want to buy the Astro wrench, you can put a small rubber band around the hex shaped part of the the Astro socket and it'll hold the socket pretty securely in the box end of whatever wrench you're using.
Ign
Butte Peak ND
I've got the OEMtools pass thru set. Can be found on Amz as ASIN B01ELYPMSK
Also this Cman set which I would guess is NLA
Steve_P
Thanks for the replies- I'll check out the suggestions. I somehow forgot to mention that I already have the Astro set- looking for something that uses a smaller wrench size on the smaller sockets. Yes, I realize that these will/can fall out of a regular ratcheting wrench, but it's not something that I'm going to use unless there's no other possibility. @Tools4Me has a simple solution for retention- awesome idea!
@Ign- That Craftsman set is awesome! Never seen that before.
KnurledNut
n/a
@Tools4Me
Thats a creative idea, but it would be too much hassle for me, especially with non-reversible wrenches. Id just as soon cram a piece of paper towel to hold it in.
Sneezer
DFW, TX
I have a Craftsman pass thru set, appears to be a decent copy of the Gearwrench set. I think the sockets work with both wrenches. Kobalt also used to sell a pass thru set as well.
I really like the Astro wrench. Didn't know about it, and I already have the 3/8 and 1/2 nano sockets.
JBH
What size is the hex pattern? I'm curious if these sockets work with the Facom/USAG, Wera, Snapon, etc. 11mm outer hex ratchets.
Tools4Me
Based on the images shown for the OEMtools set, it appears that the size of the hex increases with the size of the socket. It isn't a constant hex size for the socket range like most other sets.
ptgarcia
Alta Loma, CA
The hex is the same size as the socket. Use a 10mm wrench on a 10mm socket, etc.
Also, the sockets have a groove that works specifically with the circlip in the OEMTOOLS ratcheting wrenches to retain the socket in the wrench. Its a nice setup, especially at the price.
Nineeightyone
Pennsylvania
I've also got the OEMTools set mentioned above, they're a lifesaver in certain situations, particularly when I need a 'mid-length' socket -- I'll stuff one of them into a standard length socket and come out a little shorter than my deep sockets. The ratcheting wrenches have held up well too, which is great because the next option up was ~$130 versus the $90 I paid for the wrenches + pass-through sockets.
619DioFan
San Diego , Ca.
I don't need a ratchet, extensions, etc, just looking for a socket set like this to use with ratcheting wrenches:
Any other options besides tool truck brands?
I have these in both sae and metric. I did buy the ratchet that goes with them as well. the ratchet has an adaptor that works with reg sockets. you can also use these sockets with a standard ratchet. I use them with my HF thin ratchet. haven't tried them with a wrench. they are very short and fit in some tight spots.
Steve_P
I picked up the O'Reilly's set yesterday. They are significantly shorter than the Astro, just what I wanted! I may also get the OEM set since they're so inexpensive, and I'm an idiot....
Ign
Butte Peak ND
Well, I didn't realize the PowerTorque set(s) existed but thanks to this thread I picked up both today.
$11.90 out the door after a $15 O'Rewards thing they emailed me20210626_182913.jpg
Steve_P
I assume you're talking about the socket retainer method- that's not my idea. But I did copy it, I dont have a lathe, but it looks like I do. I chopped off 90% of an adapter w a hack saw, then put it on the side of the grinding wheel... extension worked flawless to hold it but I still wore a face shield... then on a sanding disc. It somehow looks perfect. And it works great!
Mgdoug3
KY
Your way of making is probably easier than using a lathe. I would have to switch to my 4 jaw chuck, dial it in and then machine it. Just cutting it with a cutoff wheel and then a flapper disk would probably be good enough.
