I went ahead and sent them an email. Its time to solve this mystery once and for all!
If nothing else, it may convince them that 'muricans can have OCD too.
Personally I've never attempted to use the #1-#3 combo tip so I can't tell you if its brilliant or not but appears to be a bit gimmicky and I just instead have used a dedicated Vessel #1 or a #3 tip in the ball grip. I can say that the #2 has a ton of good bite, works well and long lasting/low wear. I agree what you said about that #1 access being in tight spots.I'm sure this has come up before, but does this tip work well enough for ph1 and 3, or not so much? Just out of interest.
I guess recessed PH1 screws would be an issue.
yes, and it seems without rhyme or reason....
After looking into it more...
And we have the answer from Nepros:Nepros is very good at answering Email (and very courteous, as would be expected). Somebody ask them. I bet there's a reason...
Thank you very much for your e-mail.
I am (removed name for their employee's privacy).
As to the area you kindly pointed out, we are doing grinding process by the barrel polishing.
The below picture is not our facility but we are sending it to you only for your easy reference to explain the barrel polishing. (There was a picture in the email of a barrel polisher. Nothing fancy)
Since the polishing material does not reach the area where you pointed out, most of our ratchet handle has some part where is not polished.
Thank you very much for your voice and we will keep your e-mail for our improvement.
I'm no expert on Nepros but from what I have noticed, it seems to me that older production ones were rougher & newer production ones have better polishing or should I say some or better finishing before polishing in that area. The rough texture looks like how it pretty much comes out of sand casting or whatever & untouched or very little finishing if at all. As if they are improving their finishing process.And we have the answer from Nepros:
While they didn't completely answer my question, it does provide a little more information.
I've looked at lots of pictures of the Nepros ratchets from the regular ones all the way up to their custom wood handled ones. Some have it rough, others have it fully polished, and others have it only partially polished as seen here:
Two ratchets in particular I think hint as to the reason why: pizza's blue IP ratchet which clearly has tooling marks in that area, and the partially polished one linked above.
I think it comes down to the switch. When the ratchets are finished, they get polished with the barrel polishing process and then they QC the ratchets. Ratchet bodies that are too rough such that it would interfere with the switch will get sent off to the machine shop for a pass with a mill. Ratchet bodies that won't interfere with the switch will be accepted and sent off.
That's my guess at least.
Damn, wish I had known about the Craftsman ones & how cheap they are compared to the Vessel ones. I haven't paid attention to anything Craftsman in a long time. I think I paid double the price for mine. No matter though, still very happy with these Vessels & wouldn't hesitate to buy them again for the price I paid.I know these have been posted before but just noticed that most are now back in stock again and priced @ $6.99 Prime delivered from US, non-third party. I found the hollow ground slotted ones to be a good one to have.
Made in Japan by Vessel
https://www.amazon.com/s?i=merchant-items&me=A3AWN9JN1RIIEI&rh=p_4:Craftsman&dc&marketplaceID=ATVPDKIKX0DER&qid=1623428248&ref=sr_nr_p_4_1
It doesn't seem to be a time thing. You can find ratchets from years ago which are fully finished in that area. You can even find examples of their Urushi ratchets with that section unpolished.I'm no expert on Nepros but from what I have noticed, it seems to me that older production ones were rougher & newer production ones have better polishing or should I say some or better finishing before polishing in that area. The rough texture looks like how it pretty much comes out of sand casting or whatever & untouched or very little finishing if at all. As if they are improving their finishing process.
I have no idea if this is actually true but is what I suspected. Knowing that their demand is high a most are made in batches, when I ordered mine 1/4" & 3/8" I decided to order them together which was earlier this year hoping they would "match". Not sure if what I suspected was right or I just got lucky but both of mine have decent polishing in that area. Can anyone confirm who has bought any ratchets this year with rough finishes in that area?
Sounds to me like they are tumbling to get their desired finish before plating as most ratchets, wrenches, etc are made this way (yeah, I watch How It's Made, lol). There are 2 main types of tumblers, vibratory & rotary. Since they stated barrel polishing it sounds to me like they are using rotary tumblers. I have no experience with rotary tumblers but I do have vibratory tumblers (not huge industrial ones though). Perhaps they changed their tumbling media to get in & better polish that area or they are using multiple tumbling stages or are further finishing by hand than previous production runs?
That's my guess.
Got these in April of this year.
Do Nepros ratchets have plastic direction switches? (Was mentioned on another thread).
In the reviews on the net, there are many comments that the material of the switching lever has changed from the previous iron to plastic, and it is brittle and easily damaged, but when you rub the cracked cross section with a screwdriver etc., it will be scraped and shine silver. .. Most of the contents of the repair kit are made of iron and are attracted when the magnet is brought close to it, but only this lever does not react.
As I used it, the red paint peeled off and became white, so I thought it was a plastic resin, but
apparently it is an aluminum metal. (It's hard to see in the image)
However, in any case, the strength is weak and the result is still broken, so please return to the previous iron product.
I did a bit too. Definitely some conflicting views on this.I did some searches
Yes, it is, although it doesn’t detract from the tool at all. My roto head ratchet is shown. The ratcheting part is the same as the round head.On Koken round head ratchets is the red part plastic? I vaguely remember reading that the Koken round head ratchets had a red plastic part and black metal part. I have Koken ratchets but not the round head.
Feel free to be critical. Tool manufacturers wouldn’t ever make improvements if we didn’t!Thank you for the info, guys.
For others that haven't followed the other topics I want to point out that I was just identifying plastic components. Not criticizing the ratchets although some of the reviews that I quoted are critical.
Dave455, Iirc you have the knurled grip on the swivel head. Have you had opportunity to try the soft handle? I have used the polished and knurled handles on other Koken ratchets but haven't seen the soft handle. I tend to prefer screwdriver handles on swivel heads but I never see the soft handles shown on GJ. Wish I could try before I buy.
Sadly not. None of the KoKen ratchets of this style offer a quick release option, so I suspect the mechanism makes it difficult. Koken are not usually shy about offering options.^ Does the KOKEN swivel ratchet come with a quick release?
I'm sticking with my conclusion that they probably go back and polish that section on ratchets that have clearance issues with the switches. Also note that even the ones that do get it polished - the emphasis seems to be to polish the area under the swing arc of the switch.
Regardless of the actual reason - I actually kind of like the rough finish in that section. It stands out from the rest of the otherwise perfectly smooth ratchet.
According to my toothmeter, the 2 that I got in April this year have metal selectors also.not that i've seen. including one ordered august 2020 directly from nepros.
toothmeter is accurate enough for me.According to my toothmeter, the 2 that I got in April this year have metal selectors also.
That was one of the first things I checked when I received them although I had no idea there were rumors about plastic ones.
No, because I bought Ko-ken just to avoid that problem!So the real question, can we change the switch around so that it matches every other ratchet we grew up using? Or am I the only one that had to get used to the Nepros inverted (to me) selector switch?
Wait what? The 2 Nepros I have the selector switches are "correct". If I switch the lever to the right, I expect it to loosen a fastener by swinging the ratchet to the right, switch to the left to tighten.So the real question, can we change the switch around so that it matches every other ratchet we grew up using? Or am I the only one that had to get used to the Nepros inverted (to me) selector switch?
They look very similar to my MAC pliers and they don't have COO on them could it be possible they they are outsourced to them..While researching on Japanese amazon I came across these super small Keiba pliers. I am into small and lightweight tools that get the job done so I had to purchase. They were kind of expensive at over $115 for the set. Black leather pouch was included.
In my brief interaction with the so far, they are so small it’s almost novelty getting a job done. I tried cutting a standard zip tie with the cutter and it was a tricky two handed affair. I still may carry them in a moto bag when going ultra light.
Wera has patents on the plastic storage design --> https://patents.google.com/patent/DE102006055025A1/
If you want a bit driver set in a square box that is actually made in Japan, you might take a look at the Ko-ken catalog --> https://kokenusa.com/
M6,
Are the bits easily replaced? I have a full-size German one and if you lose those bits it costs a pretty penny to replace if you want them in the head as none fit in that head.
