Tools of Japan
macgee
Sepulveda Pass, CA
I'm sure this has come up before, but does this tip work well enough for ph1 and 3, or not so much? Just out of interest.
I guess recessed PH1 screws would be an issue.
Personally I've never attempted to use the #1-#3 combo tip so I can't tell you if its brilliant or not but appears to be a bit gimmicky and I just instead have used a dedicated Vessel #1 or a #3 tip in the ball grip. I can say that the #2 has a ton of good bite, works well and long lasting/low wear. I agree what you said about that #1 access being in tight spots.
I could see it maybe being useful for an emergency tool kit or for a minimal tool bag.
For $7 though, it's cheap to try out a Vessel driver, having the ball grip driver is great deal whether you use it for the #2, hollow ground slotted tips or to use it with your other hex bits.
FuzzyTiger
Canada
yes, and it seems without rhyme or reason....
After looking into it more...
Nepros is very good at answering Email (and very courteous, as would be expected). Somebody ask them. I bet there's a reason...
And we have the answer from Nepros:
Thank you very much for your e-mail.
I am (removed name for their employee's privacy).
As to the area you kindly pointed out, we are doing grinding process by the barrel polishing.
The below picture is not our facility but we are sending it to you only for your easy reference to explain the barrel polishing. (There was a picture in the email of a barrel polisher. Nothing fancy)
Since the polishing material does not reach the area where you pointed out, most of our ratchet handle has some part where is not polished.
Thank you very much for your voice and we will keep your e-mail for our improvement.
While they didn't completely answer my question, it does provide a little more information.
I've looked at lots of pictures of the Nepros ratchets from the regular ones all the way up to their custom wood handled ones. Some have it rough, others have it fully polished, and others have it only partially polished as seen here:
Two ratchets in particular I think hint as to the reason why: pizza's blue IP ratchet which clearly has tooling marks in that area, and the partially polished one linked above.
I think it comes down to the switch. When the ratchets are finished, they get polished with the barrel polishing process and then they QC the ratchets. Ratchet bodies that are too rough such that it would interfere with the switch will get sent off to the machine shop for a pass with a mill. Ratchet bodies that won't interfere with the switch will be accepted and sent off.
That's my guess at least.
darkzero
SoCal
I'm no expert on Nepros but from what I have noticed, it seems to me that older production ones were rougher & newer production ones have better polishing or should I say some or better finishing before polishing in that area. The rough texture looks like how it pretty much comes out of sand casting or whatever & untouched or very little finishing if at all. As if they are improving their finishing process.
I have no idea if this is actually true but is what I suspected. Knowing that their demand is high a most are made in batches, when I ordered mine 1/4" & 3/8" I decided to order them together which was earlier this year hoping they would "match". Not sure if what I suspected was right or I just got lucky but both of mine have decent polishing in that area. Can anyone confirm who has bought any ratchets this year with rough finishes in that area?
Sounds to me like they are tumbling to get their desired finish before plating as most ratchets, wrenches, etc are made this way (yeah, I watch How It's Made, lol). There are 2 main types of tumblers, vibratory & rotary. Since they stated barrel polishing it sounds to me like they are using rotary tumblers. I have no experience with rotary tumblers but I do have vibratory tumblers (not huge industrial ones though). Perhaps they changed their tumbling media to get in & better polish that area or they are using multiple tumbling stages or are further finishing by hand than previous production runs?
That's my guess.
Got these in April of this year.
darkzero
SoCal
I know these have been posted before but just noticed that most are now back in stock again and priced @ $6.99 Prime delivered from US, non-third party. I found the hollow ground slotted ones to be a good one to have.
Made in Japan by Vessel
https://www.amazon.com/s?i=merchant-items&me=A3AWN9JN1RIIEI&rh=p_4:Craftsman&dc&marketplaceID=ATVPDKIKX0DER&qid=1623428248&ref=sr_nr_p_4_1
Damn, wish I had known about the Craftsman ones & how cheap they are compared to the Vessel ones. I haven't paid attention to anything Craftsman in a long time. I think I paid double the price for mine. No matter though, still very happy with these Vessels & wouldn't hesitate to buy them again for the price I paid.
Does this mean anything special or do they all have it? I hope they all have it otherwise these might turn into drawer queens & I'd have to buy another pair. :lol:
FuzzyTiger
Canada
That's my guess.
It doesn't seem to be a time thing. You can find ratchets from years ago which are fully finished in that area. You can even find examples of their Urushi ratchets with that section unpolished.
The amount of finishing in that section also seems to vary on the ones that do have it finished plus pizza's ratchet clearly shows tooling marks that couldn't be from the rotary or tumble polishing process. So some ratchets are getting a single process polishing and others are getting a two process polishing. Noting the limitations of their polishing process as they describe it, I'm sticking with my conclusion that they probably go back and polish that section on ratchets that have clearance issues with the switches. Also note that even the ones that do get it polished - the emphasis seems to be to polish the area under the swing arc of the switch.
Regardless of the actual reason - I actually kind of like the rough finish in that section. It stands out from the rest of the otherwise perfectly smooth ratchet.
measuredtwice
USA
From the catalog:
“PROKON” is a series of tools manufactured
with a professional spirit for professionals.
This solves various kinds of problems in
construction, electric, and utility works.
"PROKON" is all that craftspeople could ask"
Do Nepros ratchets have plastic direction switches? (Was mentioned on another thread).
It's possible that I am victim of consuming false information but I had read that they were previously metal and switched to plastic. I read it in several places but the easiest to remember and find was Amazon.
measuredtwice
USA
I did some searches and this fellow claims the material changed but it is not plastic. It seems that there is a lot of conflicting information on the net. Sorry!
In the reviews on the net, there are many comments that the material of the switching lever has changed from the previous iron to plastic, and it is brittle and easily damaged, but when you rub the cracked cross section with a screwdriver etc., it will be scraped and shine silver. .. Most of the contents of the repair kit are made of iron and are attracted when the magnet is brought close to it, but only this lever does not react.
As I used it, the red paint peeled off and became white, so I thought it was a plastic resin, but
apparently it is an aluminum metal. (It's hard to see in the image)
However, in any case, the strength is weak and the result is still broken, so please return to the previous iron product.
On Koken round head ratchets is the red part plastic? I vaguely remember reading that the Koken round head ratchets had a red plastic part and black metal part. I have Koken ratchets but not the round head.
Dave455
Sussex, England
Yes, it is, although it doesn’t detract from the tool at all. My roto head ratchet is shown. The ratcheting part is the same as the round head.
The black part, which is the bulk of the “switch” is black steel. The red plastic part is really only an indicator.
Overall, this is a very high quality tool, and quite substantial. The second picture shows my roto head compared to the regular. If I’m not doing automotive work I often carry this as my only ratchet. One of KoKen’s best in my opinion.
measuredtwice
USA
Thank you for the info, guys.
For others that haven't followed the other topics I want to point out that I was just identifying plastic components. Not criticizing the ratchets although some of the reviews that I quoted are critical.
Dave455, Iirc you have the knurled grip on the swivel head. Have you had opportunity to try the soft handle? I have used the polished and knurled handles on other Koken ratchets but haven't seen the soft handle. I tend to prefer screwdriver handles on swivel heads but I never see the soft handles shown on GJ. Wish I could try before I buy.
Dave455
Sussex, England
Feel free to be critical. Tool manufacturers wouldn’t ever make improvements if we didn’t!
In practice, of all the ratchets I own, I don’t really think I can find anything to criticise on this one. It really is a favourite and I use it a lot.
On most of my KoKen I went for the smooth steel handles. I generally detest soft handles as they don’t work for me at all. (I like the older Snap On “hard handle” comfort grip, but that’s about the only one).
With a roto head ratchet you do need the ability to use it like a screwdriver, so a screwdriver handle is a good choice, but I opted for the knurled handle and it’s been great. Works as a screwdriver handle, loads of grip, but durable too.
Dave455
Sussex, England
^ Does the KOKEN swivel ratchet come with a quick release?
Sadly not. None of the KoKen ratchets of this style offer a quick release option, so I suspect the mechanism makes it difficult. Koken are not usually shy about offering options.
The only options on this one are the usual handle choices.A866288B-8B7E-4C75-BD16-4F637919934A.jpeg
pizza
Midwest, USA
i like your theory much more than mine which was: polishing that area isn't a part of their spec, and it's probably just left up to the discretion of whoever's in charge of that run. lol
likewise. i like the contrast, but i also appreciate my milled/polished samples for the extra work involved.
pizza
Midwest, USA
interesting info, @measuredtwice. my assumption is that something was lost in translation, or those guys are mistaken.
perhaps there was a redesign of the selector (steel -> aluminum?), but it had to have been before any of my samples were made.
mine are all aluminum. i think i watched AvE complain in a video about the selector switch being a stamped part, but after taking mine apart, it looks cast to me.
certainly not as robust as steel, but the switch part is 2mm thick. seems sturdy enough to me?
the 1/4" version is actually a little thicker (2.2-2.3mm) but is overall smaller and has different cross sectional geometry (more triangular).
curiously, the 1/4" uses a T6 screw, and the 3/8" uses a 2mm hex screw.
Gregthegadgetguy
So the real question, can we change the switch around so that it matches every other ratchet we grew up using? Or am I the only one that had to get used to the Nepros inverted (to me) selector switch?
And for eye candy, Nepros largest ratchet, quick spinner, extension and socket.
darkzero
SoCal
Wait what? The 2 Nepros I have the selector switches are "correct". If I switch the lever to the right, I expect it to loosen a fastener by swinging the ratchet to the right, switch to the left to tighten.
This is how every ratchet I've owned works since I was a teenager. The only ratchets I own that are "backwards" (to me) are a Tekton that I keep in my truck & a couple of HF slim ratchets which I got only in the past few years. They drive me nuts.
Just showing my Snappys cause those are the only ratchets I have that have the directions marked.
Gregthegadgetguy
I am wrong, my Asahi Lightool is the one that is backwards! Nepros and Koken are already taking over the ratchet slot in my Assistant.
I have been using the Asahi and round head types like the Wera pictured. Not sure I am ready to give it up because how good it feels after some initial lube.
darkzero
SoCal
Ah, ok I see. You had me pretty confused for a second & made me run out to the garage to re-check my Nepros. :lol:
mercifiknow
Somewhere I should be
Can someone recommend a stubby with extra tools in the head? Prefer ratcheting. Needs to be reliable, able to find replacement bits easily (USA preferred), and is RELIABLE. Have Koken tools currently and love them and would prefer to stay with them but I didn’t see one.
Hope Everyone Is Well!
Thanks!
superautobacs
Vancouver, BC
Here's a view of the barrel tumbler used for Nepros tools, at KTC's manufacturing plant.
taken from this thread: https://www.garagejournal.com/forum/threads/ktc-kyoto-tool-company-its-tools-and-tool-museum.163056/
Unless you use a very small media in the tumbler, you won't be able to smoothen out the rough spots left behind from the hot forging stage. Even if they did, it'll take too much time and probably adversely affect the overall finish. Instead, they could CNC mill that surface area but that would drive up production time by a lot and that'll equate to higher production costs. I see nothing wrong with it; I like the rough, 'raw' texture...a mark of a hot-forged piece of their 5GQ alloy steel.
TjoFrasse
Sweden
Some Japanese tools I've gotten recently:
I wanted a locking screw extraction pliers, but didn't want to go Engineer with my recent disappointment with them. So thanks to this thread I got the 3peaks instead. It has nothing to complain about this far. Well made!
Then three 10mm wrenches for the collection. The ASH I found at a local flea market, the KTC and Tone was bought from Amazon Japan. The Tone isn't made in Japan, but the others are.
The KTC 1/4" ratchet was another purchase out of curiosity. I was a bit hesitant over it since it's only 36 teeth, but I was surprised by how smooth and nice it is!
The Vessel stubby bit handle was just something I threw in to the Amazon order since I can't get enough stubby screwdrivers...
The Koken tap holder I got have the set. I got the bigger version previously and wanted to secure the set.
Then just a random 10mm Koken socket that I found at the flea market. The chrome has wore off the end, so has probably seen heavy use...
I also got two key chains from Amazon. The Sunflag is interesting, with it's flat design PH2 end. It was very inexpensive but also just a stamped piece so...
The Tone is again not made in Japan, but very cool. A fully working PH2 screwdriver, perfect for a stubby screwdriver collector like me!
XxToolAholicxX
SF **** Bay Northern California
While researching on Japanese amazon I came across these super small Keiba pliers. I am into small and lightweight tools that get the job done so I had to purchase. They were kind of expensive at over $115 for the set. Black leather pouch was included.
In my brief interaction with the so far, they are so small it’s almost novelty getting a job done. I tried cutting a standard zip tie with the cutter and it was a tricky two handed affair. I still may carry them in a moto bag when going ultra light.
They look very similar to my MAC pliers and they don't have COO on them could it be possible they they are outsourced to them..
thursday
Utah
Thought I would ask you guys if there's something similar to the Wera 056490 Tool-Check Plus Ratchet Set.
It seems like the Japanese would have something like this but I can not find anything. Most interested in compactness and versatility of the kit to fit in a small toolbox.
Link to product in question:
thursday
Utah
Wera has patents on the plastic storage design --> https://patents.google.com/patent/DE102006055025A1/
If you want a bit driver set in a square box that is actually made in Japan, you might take a look at the Ko-ken catalog --> https://kokenusa.com/
It doesn't have to be plastic. Just looking for a compact kit.
I found the Facom Nano which comes in a plastic kit and is very similar to Weras offering.
Seeing if anyone here knows something similar from a Japanese brand without referring me to a catalog.
M6erfan
'Merica!
Ok found the Koken stubby but no bits in the head or ratcheting. Suggestions?
KTC DBRS06. Probably made in Taiwan, not easily available in the U.S., not inexpensive. But it's a ratcheting stubby with bit storage in the handle from a Japanese Co.
mercifiknow
M6,
Are the bits easily replaced? I have a full-size German one and if you lose those bits it costs a pretty penny to replace if you want them in the head as none fit in that head.
