Hi! I moved into an apartment last Fall and noticed some strange musty odors coming in through a kitchen cabinet that shares the wall with the attached garage and a similar problem in the master closet that is also attached to that same wall. It was a brand new construction and I was busy moving in, so I didn't think much of it. I assumed maybe it was the building materials off gassing. Then it got worse and everything in my closet was ruined - my entire wardrobe had to be tossed because the odor was so disgusting. I started wondering if it was just my items because they had been packed for about 3 months prior to moving in - threw just about everything out and completely cleaned. The smell is still just as bad and I can feel warm air coming under the baseboard that shares the garage wall.
The odor in the cabinets on the lower wall in the kitchen and the closet and now a lot of the house absolutely reeks since it's been humid. Also, our central AC just will not keep the humidity under control at all - over 70%. Upon investigating I can see where the drywall in the garage meets the cement, there's no sealing. Then along the wall by the kitchen outside in the garage there's a baseboard - but under it you can see straight through to insulation and framing. So it looks like concrete floor, some concrete going up - the concrete stops - there's a baseboard and under that gap between the concrete and the baseboard, there's wood beams and a grey insulation. On the side walls, it's the same but I can't see the actual boards - I see drywall with a rough cut that meets the concrete walls and the insulation kind of hanging out underneath.
Our air intake for our apartment is over the garage door and it's sucking in air from the garage and blowing it all around our living space which is just truly disgusting. I contacted the apartment complex and someone says they're coming to seal it hopefully this week - but I'm just a little worried that maybe there's a bigger issue or mold or something inside the walls? Luckily we have never parked our car in the garage - but honestly once in a while I smell gas fumes and each of these apartments has an attached garage so the neighbors garage is up against my other kitchen wall.
Do any of you guys have experience with finishing garages? This totally isn't normal right?
