ambenz
NW Chicago Suburbs
One of my car show flag dowel rods broke inside of my trunk after a recent car show.
So upon further inspection of the whole assembly of my formerly rigged, hanging bar stand and three flags, I see I had different size dowel Rods on each flag. One was plastic, one small, and the broke one.
The flags were also pretty dirty so I unstapled the flags and put them in the wash to be cleaned.
So I restrung the flags on new dowels but I had to resize the holes on the bar to fit the uniform sized dowels now holding the flags. My good old drill bit holder gave the right sized bit and my King Seeley Table drill press made short work of the flag holding bar....
Once I got the bar holder drilled, all the flags fit into it bar holder...
The bar also has screws to lock in the flag poles so I could put American flags into the bar and actually drive with the flags flying in the back. The screws make sure I don't loose the flags even during the heaviest wind.
The bar fits in back of the seat and forward of the tonneau cover and is secured below the covers bungie cord hold downs.
All this hub-bub for car show flags? I suppose sometimes in life, the simplest things are a pleasure to work on.
During a cruise in....
....I suppose I should go back and paint the rods black..... *sigh*
rshadd
Doylestown, PA
Change the oil on my Ariens ST824 Sno-Thrower. Then pressure washed it and waxed it. Finished up by adding some Ethanol Shield to the gas tank and lubricating every thing.
harley jim
Cleveland Tn..........out in the sticks
Any self respecting street rodder would.
Jim1932
Put lots of stuff that was in, or on, the garage in a dumpster.....
2baditsnotachev
MN
Yes, we race a no time dot class. It requires dot tires and basically all steel and glass, and fully finished interior. It did very well with the sbc turbo motor the last couple seasons, now we see if we can manage all this extra power.
JDGolden
Nothing today, but I REALLY need to clean and organize it. I swear, I never have enough room for all of my stuff.
Forgottonia
edge of Forgottonia
My son found an old timey game of Operation in the basement. The battery compartment was stuck shut--screw was stripped, and the batteries were corroded in. I'm cleaning it up and reworking the battery compartment a bit to see if I can get it to work.
I think it'll be fun to play this old timey game with a post millenial kid who normally plays mostly online games.
Zrsnopro97
Finished installation of new ceiling panels. Wired most of my 8' LEDs and cleaned up.
Close to ready to start the 2000 hrs.
Of finishing my twin engine aircraft.
What’s the name of that ceiling panel called? Where do you purchase it at? Looks great
Slednut
Washington state
Installed the two rear side windows in my 70 Cyclone and got one of the door panels installed. Except for the fuzzies they are the panels that came on the car.
brownsmustang
SWMO
Drove 6 hours to get this 1940 GE fridge, got it home and checked out the compressor, wired it direct and it cools. Now just gotta rewire it and get the relay rebuilt.
Flat Thunder Channel
Been away cruising the family fun mover across a couple states for a beach vacation. We rented a Chrysler Pacifica mini van. Talk about a cush ride! Of course I branded it with the channel logo. The wife was not amused at first, but eventually came around to the idea..... Flat Thunder on the open road. Haha
Nick's Cheese steaks & Subs definitely gets a thumbs up! Great food!
Hope to get outside for some much needed cleanup work in and around the garage this weekend.
PhantomEB
Medicine Hat, AB, Canuckistan
More stacking of boxes from the basement out there so it’s an easier move next month. Prestaging boxes I know more of the content to be the first load as I know already where most is going. I refuse to drop it all in the living room, if i have a spot for it, then it’d getting there right off the bat.
Prospecter
Maine
Cut siding to install on my new 14x24 shop. I know bigger is better but being in the city this was the max I could build. 66EDC423-5BF3-4E18-8FB1-8096305263FB.jpeg297960DF-C4B8-483A-B7EA-CAF00B8AB0EC.jpeg
That looks like a good size to me! I work on vehicles in a 12 x 24 area of my shop, and often wish I had an extra 2', though the 12' is workable. One thing about bigger is more steps to get about. I imagine you will be quite happy with that size.
vertguy
SE WI
Started some long overdue maintenance to the garage man door jam. In addition to sanding and repainting the the peeling exterior portion of the jam, also repaired/patched the area in front of the deadbolt plate (door was closed one time too many with the deadbolt extended), and sand/painted the interior portion. Looks a ton better, but I still need to remove the door and paint that interior jam area as well. Yep, it is just a garage entry door... but it bugged me every time I was working out there with the door open.
Of course my wife thought my time would be better served repainting the pantry door, so I guess that project needs to completed before I strip/repaint the garage door :bounce:
