Amazon Warehouse Deals
Crabman
Alexandria, VA/Dameron, MD
So needed some fuel stabilizer, looked for Sta Bil my go to. Mostly use ethanol free gas in boats, lawn tractor, generator, etc.
Anyway Amazon has the 32 oz bottles for $8.88, which I think is the cheapest I have ever seen. The camel says lowest in 2 and a half years and second lowest ever. Shipping is early August.
2manytools
Mt Pleasant, MI
Thanks for adding you only use it in ethanol free gas. Definitely need a different product that controls ethanol if trying to store non-recreational gas, if you want your lawn equipment to last & not need service all the time.
Good price
purplezr2
Central MN
Good price
States in the add above that it works on all ethanol blend fuels.
Crabman
I always had the best luck with Star Tron when I was battling ethanol fuel. My old marina would not carry ethanol free because most people did not want to pay the price. They paid the price instead with constant fuel delivery issues, water in tank, carb rebuilds, but I digress.
On to the deals.
Astro Pneumatic Tool 2181 8-Piece Double Cut Carbide Rotary Burr Set 1/4" Shank in Blow Molded Case​
Regular $59.99, used very good $37.75
GeoBruin
On to the deals.
Ive had good luck with this set. Even if one burr is shot, it might still be worth it.
D
Duker
Livingston, TX
Duker,
Welcome back, I hope all is well with you.
Bruce
Yes welcome back, last Saturday was not the same without your posts.
Thanks guys, just came back from a “Griswold Family Vacation” in Colorado complete with drunk uncles, hospital visits, and a plethora of other fun and excitement.. sooooooo glad to be back home although I miss the cooler weather.
D
Duker
Livingston, TX
D
Duker
Livingston, TX
D
Duker
Livingston, TX
I thought these might work in catching oil drips from under a car or using as mini spray paint tarps etc… lots of uses…
BOX USA BKAS4537 Anti-Slip Pallet Paper, 37" x 45", Kraft (Pack of 100)​
D
Duker
Livingston, TX
Alloy Steel Set Screw, Black Oxide Finish, Meets ISO 4029, Hex Socket Drive, Cup Point, M6-1 Thread Size, 6 mm Length, US Made (Pack of 100)​
D
Duker
Livingston, TX
Bright Star LED Lighthawk Gen II Lantern – UL Certified Intrinsically Safe and Waterproof Industrial/Emergency Work Light – Long Run Time Rechargeable Lithium-Ion Battery – Super Lightweight​
D
Duker
Livingston, TX
D
Duker
Livingston, TX
Not sure what I would use a coupling this big for but hey it’s 2 bucks!
Climax Part RC-100 Mild Steel, Black Oxide Plating Rigid Coupling, 1 inch bore, 2 inch OD, 3 inch Length, 5/16-18 x 1/2 Set Screw​
D
Duker
Livingston, TX
D
Duker
Livingston, TX
Use for a sandblasting cabinet…
Linemaster 3C-30A2-S Clipper Airval Foot Switch, 3-Way Pneumatic, Single Pedal, Momentary, Single Stage, No Guard, Black​
