rattle_snake's random shop projects v0.1
OutlawDrifter
KS
Justin, I have built mine in the past with steel braided line and AN fittings. The pressure hose on the '49 is in this configuration currently.
I would imagine in the greater PHX metroplex, there are more than 1 competent hose shops available. Equipment dealers would be a good place to start for variety if you don't have a dedicated shop(seems unlikely).
I've done similar to bradpac, get the hose and fittings, cut to size, clock them with paint marks, and take them back to crimp.
There are very few areas I've been that don't have a dealership/parts store/etc that has a hose crimper. If they don't have the fitting end, they could always splice the hose for a temporary fix to get you going (obviously not a fix for a bad fitting, but more likely to have a leaky hose)
In a past life I ran a John Deere dealership parts counter, and made a lot of hoses for non equipment related sales, everything from transmission cooler lines, pressure washer hoses, etc.
Just food for thought. For just straight durability, a high quality hose with a crimped end will give you a lot of miles. AN would be the easiest to service on your own out in the field though(lots of dollars in parts to carry in the tool box though).
R
rattle_snake
Chandler, AZ
So you used standard AN line? Looking at specs of the #6 summit premium nylon I have, it's rated to 500 psi. SS version is 1000 psi. My pump is configured for 1450 psi.
I see summit has P/S specific hose (PTFE) and ends in different brands. Some have AL fittings. Only one flavor that is not bright SS, fitting not in stock.
Yes there are a few local hose shops. hit and miss, expensive.
Thanks for the ideas.
OutlawDrifter
KS
The stainless braided hose I used is rated for 1500psi(Jegs house brand) it's the same hose that I used in my Z28 when I did my first LS swap.
AN line/fittings, or crimped hose, either way you're tying up some dollars.
Check ICT Billet, they may have fittings that suit your needs in black...I believe they are even made in Kansas USA.
R
rattle_snake
Chandler, AZ
Cool, thanks.
Yes I would prefer black hose and fitting so they blend in. Price is not a big deal, especially given what system it is.
ntsqd
Lower left coast
If you're going to convert the system over to AN/JIC I want to suggest a couple things.
First, AN is the same fitting geometry as JIC. JIC is the industrial form and is rarely available in aluminum, most commonly it is found in steel, brass, and sometimes stainless. AN is available in aluminum, steel, and stainless. Both use a 37° sealing angle and fine thread bolt threads. SAE fittings are 45° sealing flares and don't interchange. Unfortunately they also use fine thread bolt threads and tube size for tube size the threads are the same except for -8. Natural Gas and LPG systems use SAE fittings and those are what the local hardware store has on hand. I throw away anything that I either know or suspect to be an SAE fitting. I do not want them getting mixed up.
1) Use only steel hose ends and adapter fittings in PS and brakes. SS is probably OK, NEVER aluminum in these two systems. There's exceptions, but they rarely if ever apply to anything street driven. It's just not worth it.
2) Tom Lee (Lee Power Steering) told me ~20 years ago to never, ever use a forged angle adapter or hose end in PS systems. Always use the formed tube type of hose end on straight adapter fittings. The forged and drilled type of fittings are a really good way to introduce cavitation.
Can root around in the Weatherhead part of Eaton's page to determine hose and fitting compatibility. I can try to have a look this evening as I have one of their older catalogs that lists all of that info almost straightforwardly. I'm not a fan of race car type braided SS hose. When weight isn't a huge factor and you have room for the bends in the hose (industrial hose usually has large min bend radii) there are better options that won't abrade whatever they're laying on or happen to be in contact with.
Bigblue&Goldie
Black braided hose and steel JIC fittings are what we run on our race car steering. I couldn't find a pic of the steering, but this is the control manifold for the Dakar jacks (run on the power steering pump) on the old trophy truck.
zmotorsports
Northern Utah
Justin, we recently switched over from Parker hose to Gates at our shop at work due to corporate buying program. I really liked the Parker hose in all of the past 30 years we've used them, however, I have no complaints about the Gates Megasys hoses and crimped fittings/ends we are now using either.
For home use I have also been using the Gates as my local hose supply house uses them as their standard hose and fitting setup. On several hydraulic assist systems that I have installed on Jeeps I have been using the Gates blue hose which has a 3k PSI burst pressure and my power steering pump has a 1450-1600 PSI range. Keep in mind that many times the higher burst pressure hose that you use the bigger bend radius you end up with so although you want the burst pressure higher than your relief pressure you don't want to go crazy.
I recently just replaced a hydraulic hose on my generator slide out on our coach as well with the Gates hose and it has worked out well thus far. I can personally recommend either Gates or Parker and prefer the crimp on fittings vs. the replaceable ones such as Earl's although I have used them on occasion as well in a few street rod and race car applications.
ntsqd
Lower left coast
Did not get the chance to look at the catalog. That black Dacron over-braided hyd. hose is the stuff that I like to use too. The stuff that I have is stiff and does have a large bend radius, but it has been in intermittant service on a 2.0L ACVW's oil system for almost 30 years.
I prefer the screw-together hose ends for the field repair option. With brake hoses I buy enough extra hose to make the longest hose on the vehicle, and one extra hose end of each unique type. Those go in a sealed bag and stay with the vehicle at all times. Not sure that I'd do that for PS hoses. Not fun, but can drive it w/o PS, but w/o brakes......
R
rattle_snake
Chandler, AZ
Thanks for the info.
I ended up ordering R17 hose (more flexible) and crimp ends. Now I'm starting to get backorder notices.. poo.
Perhaps local shop has fittings in stock. I think I have the rest of the parts. Not going to take anything apart to build brackets until I have everything.
R
rattle_snake
Chandler, AZ
Decided to revisit the 72 Ford's front bumper to address some shortcomings and bring up overall quality level to that of the rear bumper. During build I was on the fence about reinforcing the clevis mounts, skipped in rush to finish. After getting some feedback from Bodj on bumper face defection if clevis is loaded sideways, I wanted to improve. Mike also later commented on mounting clevis mount to frame support directly. I appreciate the feedback I get here, positive or negative, always learning from other's experience. So thanks to Bodj and Mike.
Added a pair of supports orthogonal to the face plate to prevent deflection of face. Even the short length of the clevis mount when pulled hard from the side will want to tilt, and deform the metal around it.
The supports tie into the frame mounts.
I also spent some time turd polishing the fit and finish. I reworked all the corners on the top, added radius and smoothed everything out better. Also redid the upper/outer edge radii, to a better quality level. More consistent radius, smoothed and filled in some remaining pits and low spots. Then sand and repaint.
The metallic silver rattle can leaves bad tiger stripes and rough surface from flakes. Figured out some ways to mitigate and hit final coat with extra fine scotchbrite pad.
R
rattle_snake
Chandler, AZ
T56 trans in Cobra is stuck in 1st gear. Shifter will move through gate positions easily but will not pull 1st syncro back out. Guessing shift fork slider keys broke and fell off.
I have not abused this transmission. No power shifts. So surprised it is broken like this. It's made it's share of 1/4 mile passes on boost/nitrous/slicks, but with granny shifts.
I've had the trans out and apart for a 26 spline input shaft upgrade, McLeod dual disc clutch. Not a fun job.
Guess it is time to buy a transmission jack for use under 2 post lift. :rolleyes:
Too bad the lift is a floor plate style, maybe jack is useless?
LXCam
That ***** J, just do yourself a favor and get a dual stage. I had to do the trans on my truck two weeks ago and was so used to the NAG1's in the cars I didn't give it much thought using my single stage jack on my four post. It forces me to lift the trans off my hydraulic table at about 3ft and set them at about the 5ft mark on my trans jack. The NAG1's are maybe a little over a hundy without the converter in them. That damn HP70 in my truck, I swear that FN thing is pushing 2. Coming out was fun.........going back up and in about got the best of me.
R
rattle_snake
Chandler, AZ
Thanks for the tip cam. ya, not my favorite job...
T56 is about a buck twenty five.
Justin, did you pull the shifter off to have a look? Might be worth an inspection.
No but will do that before anything else. I did pull the boot off to make sure shifter was tight and connected. Had kids to get to sports so limped home and parked it.
At least it's clean and rust free.
Bodj Built
Moorpark, CA
Bumper looks so good! Great job with the fit and finish. Your attention to detail is way better than mine. Glad I could be a good influence on the clevis supports haha
R
rattle_snake
Chandler, AZ
I just needed to slow down but I'm not good at that. weld paint install.
I have PS hoses made right at Hose Power. Always steel fitting too.
Thanks will try them if needed. I got a few parts next door at advantage.
Online order at discount hydraulic went sideways. Website doesn't show what is in stock. Half was backordered after payment. A shipment went out of unknown parts. $30 in shipping for $40 order. Poor communication. Nothing yet a week later.
R
rattle_snake
Chandler, AZ
I pulled the shifter boot out of my cobra and found that the shifter tower bolts were loose. The rear bolts were backed out a good 1/2" and allowed the shift ball to come out of the rail. I run a MGW shifter and put in a special neoprene gasket. I think the gasket caused the bolts to not torque properly and back out. I left the gasket but put some blue loctite on the bolts. Glad to no have to pull the trans.
Domestic projects pilling up. Installed new dishwasher last night. One more bathroom sink to go...
LXCam
I think it better safe then sorry Justin. You should buy that dual stage trans jack and have it ready for a rainy day.
That way I can borrow it ;) .
Glad it wasn't the trans bud :drink:
R
rattle_snake
Chandler, AZ
Ya Cam I think your right. I've only done it the hard way, alone on the ground.
You know, it would be just as coinvent if you picked up a nice high end dual/telescopic unit that we could share. Given you have Chrysler products you probably use it a lot more than me. 😂
That's a win for sure!
I needed one. So much other stuff to fix/maintain/repair/replace. Such is life.
LXCam
Ohhhh ouch!.
Whatta they say in france.....oh ya.......douche'e
:Twitch:
R
rattle_snake
Chandler, AZ
Analysis paralysis on hydroboost project so distracted myself with some wood working. Made a pair of shelves to replace some crude ones I made out of a cabinet door long ago.
More of the same 'barn wood', in this case 8/4 popular and 6/4 maple.
Kept design simple and similar to the other pieces. Finished with water based polycritic.
Bears Fan
Indiana
Great stuff! Nice job on the Ford bumpers, awesome idea on using the old bumper for a shelf in the garage and your living room has a really cool style 🍻
R
rattle_snake
Chandler, AZ
Nice addition to the barn wood collection Justin!
Thanks Marc. I think that's about it for the collection. Lots of other house projects on backlog.
Thanks I like old junk on my walls but no other junk laying around.
Wife said room was too 'brown'. I told her we could park motorcycles in it to bring in some color. Ended up painting one wall grey.
R
rattle_snake
Chandler, AZ
Brakes on my 72 F250 worked excellent from factory. Dual piston front discs, big drums in rear, dual diaphragm vac booster, 32" tall tire, worn out 390 2bbl.
Fast forward to 1994 F350 axle swap, mild 460, 40" tires. Brakes are essentially the same, dual piston front discs, big drums in rear. Same booster, same master cylinder. Performance significantly degraded. Part of this was lower engine vacuum level (10-12"). The big tires directly reduce braking torque.
So hydroboost it is
Ford hydroboost units are harder to find than the chevy favor.
If you buy a renam, they do not come with the booster to master cylinder push rod, spring or clip. The length of this pushrod is vehicle specific.
Ford SD unit
So that leaves a few options
- junk yard unit {perhaps just for core and MC push rod)
- reman HB plus rod (if you know what lenght you need, and can find one to buy)
- New ford Motorcraft, complete.
I found a Chevy HB in local JY for $80. The pedal rod was significantly shorter. The MC rod was also significantly shorter. The pedal rod bore size is larger and would require a different bushing. The nitrogen accumulator was damaged and loose.
Ford vac booster pedal rod length = 9-1/8"
Chevy HB pedal rod length 5-3/4"
difference = 3-3/8"
Ford booster spacer 3-3/8" (magic?)
Ford MC rod length = 1" protrusion from face
Chevy MC rod length = flush to face
Ford MC stud spacing = 3-3/16"
Chevy MC stud spacing 3-1/4"
So several differences including mounting plates. This unit could be made to work. It would not allow a spacer on firewall, and rod will be short by mount plate thickness, which is OK and would move pedal height down, relocate brake switch.
Whould need to use a Chevy MC. A ford MC could be used, but would need mount holes hogged out and a longer MC push rod, or a rod spacer/extention. Also have to get a different nylon pedal bushing.
I choose to return the junk unit and buy a Motorcraft BRB33. This is for a 99 up super duty, although there are more than one flavor of those too. This gets me the rod lengths I wanted, correct pedal bushing bore, and a new high quality unit.
BRB33 pedal rod length = 7-1/4"
Firewall spacer needed 1-3/8"
MC rod length = 1"+ and square end
So I cut a rectange and drilled some holes to make a custom mount plate out of 3/16 plate. This allowed me to use factory captive nuts on pedal assembly, and some 2-1/2 3/8 studs. Quick and easy, no mods to truck.
To work with 1972 MC, the push rod is 0.060" too long. Easy enough to modify, once you figure out how to remove the retainer...
To work with a 1994 F-350 MC (BRMC38), the end just needed to be radiused. Pop it in your lathe...
Orientation/clocking
HB units can be installed at any angle, but there is an 'up', as installed by the OEMs, hoses on top. The mustang 4.6L is at roughly 90* and has a special MC with mount hole vertical, accumulator up. The older models have a drain channel on the 'bottom', newer ones do not have one.
I test fit the unit upside down. return lines pointed at header. looks kind of goofy, puts spool valve underneath, opposite of MC reservoir.
Fittings
Newer (90s up) HB units have an 18 x 1.5 mm o-ring inlet and a 16 x 1.5 mm o ring outlet. The two outlets are on the same side. Older have inverted flare. Most convert to AN6, so the metric to AN adapter are easy to find. I would only use steel fittings for this application.
Hoses
Bumps have a 3/8 IF pump outlet and a 5/16 IF P/S box inlet. Some use IF to AN adapter and just AN6 to AN6 hose. I used 90* IF hydraulic hose ends and 90* AN6. My hoses are about 32" long. I bought hose ends and bulk hose to make custom length hoses, with proper end fitting clocking (due to the 90s).
Another option is field serviceable hose ends and matching Teflon lined hose. They are expensive and odd fittings (like 5/16 IF 90) are hard to find. There are both aluminum and steel version, suggest only steel. I could not find all the pieces in stock of any given product family at the time.
After test fit I adjusted spacer length to get pedal in same location so I would not have to move the brake light switch. I also added booger welds as clocking keys to the HB bore like the OEM plate.
differences in super duty vs bumpside mount plates.
I went with a new dual return pump reservoir for a few reasons. ACDelco 19207054. New one is intended to be mounted at an angle, but with cap level. The offset design allow more clearance to A/C pump to get belt on/off. Fits perfect. I was able to run a 1/2 shorter belt and get pump more vertical. This solved interference problem of fluid cooler return lines also.
After fitting hoses, I had them crimpled at local shop. Installed existing MC at this time with some washers to space it out. One change at a time.
I was going to bend hard lines off of HB and use shorter hoses, hidden down by steering shaft. This puts them near header and I was worried about heat transfer. So I kept things simple and just uses hoses with 90s and ran them forward, direct to pump/box.
So, how does it perform? Sensitive. Only needs light pressure to stop now. Any more locks up rear brakes. Guessing 2x-5x the assist level over vaccum setup.
I put some miles on it and it's going to be OK. One cheap AN to metic fitting is leaking. MC is still leaking badly.
Next step is the new Ford motorcraft MC, BRMC38, to match the axles I have. Rear circuit will get adjustable proportioning valve and a #10 residual.
OutlawDrifter
KS
Hose solution vs hardlines will be more serviceable on the road for sure.
Looks good to me! That AC Delco part probably added 25hp to your BBF;)
The correct MC and adj. prop. valve should make a huge difference in driveability. I have considered doing hydroboost on the Z28 when I upgrade the front brakes to 98-02 F-body units.
bradpac
Central TX
Beautiful job, having good brakes is a must with a heavy truck. I did a hybrid Chevy/Dodge hydroboost setup on my 92 D250. You are right about the rear brakes being more sensitive, an adjustable proportioning valve is a must, luckily my rear self adjusters aren't working right so I don't have an issue anymore, don't have much rear brakes either, but that's the next project. The fronts do work really well though. Thinking a disc GM 14 bolt swap or adapting factory 02up disc brakes. Too bad newer truck axles are wider and I want to maintain the oe look.
ntsqd
Lower left coast
FWIW a friend discovered that the threads on the rear of those H-B units (his anyway) are the same as a D44 front spindle. He used a D44 wheel bearing adjuster nut, which reduced his required "special tools" by one.
If the brake bias seems pretty close and it only locks when very light in the bed you might try an LBS. It simply delays the pressure rise to the rear brakes. It does not reduce the pressure. http://www.bcbroncos.com/ used to and may still carry them.
Monza Harry
Windsor ON
Justin The Astro/Safari (AWD) of 1990 vintage came with Hydro Boost which also had a power steering/brake booster cooler line ran into the up front air stream about 3' across and back [so ~6'] in the wind, this makes me believe heat could/would become an issue, especially someone living in the desert. If I remember correctly they did the pressure side, but I believe low pressure side would be as effective/easier and safer. Just something to watch/think about for future upgrades, because you just don't have enough going on right now! :ROFLMAO: Lookin' Good [for a Ferd] Harry
Edit: Low pressure side requires 2 as the returns are separate, so not quite easier, adjust as required.:lol_hitti
zmotorsports
Northern Utah
Great job on the HydroBoost addition Justin. For the hydraulic side of the system I think you will be perfectly fine with hoses vs. rigid lines.
I also agree with Marc that the GM HB probably added HP to your ride. :cool:
ntsqd
Lower left coast
The PS box works the fluid a LOT hard than does the H-B unit. Wouldn't worry about a cooler on the return from the H-B.
FWIW I have never seen a cooler on the high pressure side, always on the low pressure return side. That is also where I put the hydraulic fluid cartridge filter. Not only adds a filter to a system lacking one, it also increases the fluid volume in the system. I tend to use the smaller version of 90's+ Ford F series OEM aux trans coolers for PS coolers.
That a cooler could be done on the high pressure side is possible, but that makes the cooler orders of magnitude more expensive.
R
rattle_snake
Chandler, AZ
I heard that's only true in reverse, haha
I think you can cut down just one side of 14b housing to use 2 short side axle shafts to narrow
Interestingly the factory 1972 brakes have one of those on the front circuit, to delay the faster acting discs. It is built into the 'T'. I may remove it if having bias issue.
I try to over complicate, more fittings to leak. Ended up going full circle back to original plan with just hoses.
I'm afraid the Toyota P/S cooler negates any HP gain from the GM reservoir?
Yes that was my initial finding as well. Pumping brakes has no impact on engine RPM, but turning the wheel loads the engine noticeably. Most people only run coolers/filter on the steering return.
What filter cartridge do you use?
So far happy with steering assist and performance. I modified pump for additional pressure and flow. It seems to handle 40s OK so far on pavement and aired down on mild trails. Rock pile may be a different story.
