Questions about my garage save project
thelucash
Hi all, I have a 25x27 2.5 car garage from the mid-70's that was built on a flat slab with no curb of any kind, and built entirely of untreated wood. Due to rising soil levels and rotting sill plates (along with constant termite/carpenter ant infestations), I decided to cut the bottom 16in of the entire structure out and replace it with two courses of 8x8x16 concrete block on the load-bearing sidewalls, and 4x8x16 on front/rear nonstructural walls. The block walls are anchored to the slab with 1/2in rebar 6-8in deep in the slab every other block and all cores filled with acrylic-fortified sand mix for grout. The 2x8 sill plates are anchored into the stemwall with 1/2in anchors into the grout. This was all done DIY.
My questions are this: will this newly modified structure have the same wind-load resistance as before with the split wall? Will it resist stresses in a similar manner to before? Did I do anything wrong?
paulsomlo
Northern Colorado
I have the same situation. As far as I can tell, my garage started as a flat slab, then evolved into a carport, then enclosed. I've got 2x lumber and 4x4 posts sitting right on the slab, no foundation, with the "garage" floor sloping about 4" from side to side. I've actually considered helical pilings with a suspended floor, like a parking garage.
quickfarms
Southern California
If the structure is good and sound that is a candidate for bracing, jacking, then demo the old slab and build a good foundation and re pour the Slab and set it back down on a new sill plate. You will either need to shorten the long wall or extend the short wall
billconner
Thousand Islands NYS
I would have liked thread rod set in slab to be continuous through new sill or at least overlapped and wired the j-bolts to the rebar dowels. Blocks with mortar is not great in tension be even with grout. But probably fine if not frequent hurricane force winds.
T
thelucash
The rebar dowels do go from 6-8in deep in foundation all the way up to the sill plate, would've thought that to be sufficient. Though perhaps I misunderstood what you said. And it is unlikely to be exposed to hurricane-force winds anytime soon, as I live in an urban area of SW Michigan 🙂
Dan in Pasadena
Pasadena, CA
Bill is talking about resisting uplift forces in the event of very strong winds. He’s saying the sill should be bolted down through the masonry into the slab. His comment that masonry is not particularly strong in tension refers to resisting those strong uplift wind forces IF they occurred. But I think you’re saying the rebar through the sills just function as a locating pin rather than bolting it down. It is possible I am misunderstanding what you did when you wrote, “The rebar dowels do go from 6-8in deep in the foundation all the way up to the sill plate.”
On re-reading that you do NOT say the rebar extends THROUGH the sill plate. Does it? Bottomline for me is the rebar into the slab should have been PROPERLY epoxied into the slab (slab drilled, holes brushed and blown dust free - manufacturer’s directions followed closely), then embedded in grout inside the masonry cells and the structure above bolted to the masonry at minimum though I’d much prefer those bolts extend into the slab and also be properly epoxied in.
T
thelucash
Oh, I understand now. Correct. I did not bolt the sill plate itself to the slab through the masonry. Is there a way to do this after the fact? I'd like the structure to be as strong as possible. I have a rotary hammer so I could conceivably just drill down into the slab with a long enough bit. Does code require the through-bolt? Will it be fine in non-hurricane high winds?
Dan in Pasadena
Pasadena, CA
Yes you COULD do it after the fact driving down through all but I honestly doubt if you need to. i don’t know the code requirements in your area but sine you don’t live in a tornado corridor (I think?!) or in Florida where there are hurricanes you’re likely fine. You’ve done a LOT of good work.
PS: Some of these questions should have been answered before you started but you’ve done damn good work. Be proud!
rayra
Escaped from Los Angeles
How about at least giving us a general location and what sort of seasonal storms / wind forces you are talking about.
T
thelucash
Tornadoes are exceedingly rare in this area(southwest Michigan) and the house has stood for about 100 years with nothing holding it to it's foundation except its own weight - so I think wind uplift probably won't be much of a concern. And thank you! I'm mostly just happy not to have to worry about termites, ants, or rot anymore. Haha.
firebirdparts
Kingsport, TN
Sounds like a solid job. Filling the blocks to enclose the rebar is a heavy-duty touch. I think anchors from the framing to the block could be very modest and you'd have quite a bit of strength there.
CraigStu
Blacksburg, Va
I don't know the details but there are several types of anchors pretty much for this purpose. I'd look at what is available and pick the one that would require the smallest hole be drilled through the wood. But even if you need say a one inch hole, you can get some extra thick washers to put under the nut or bolt head. Short of that, a bunch of Tapcons
would satisfy me even if they are not code approved.
NUTTSGT
Northern Central Ohio
If you don't have the sill anchored to the foundation, I would take care of that.
If it needs more than that, well, I'd guess you will have more to worry about when the time comes.
Nice work you did from what I can see on my phone.
Leaflessshadetree
Don't ask.
I agree. Do somethng to anchor the sill to the blocks at least (better if it continues to the slab).
I'd also put in a "gasket" (typically foam) so the wood isn't in direct contact with the concrete.
T
thelucash
To clarify, I did indeed use sillseal roll foam(and a PT 2x8 sill), along with bolting the new sill to the stemwall.
loganb
Omaha, NE
If you're really concerned about wind, I'd probably take a closer look at the rafter to wall connections. Anytime you see a picture of a roof blown clean off a building and walls still standing...yeah makes for good media but it's sign of poor construction. Toenailing rafters down to the top plate isn't enough to resist straight line wind gusts and hurricane ties should be far more common then they are. Don't need them on the same spacing/size as Florida does, but improving the connections between sill plate and stud and then top plate to rafter will dramatically improve resistance to uplift wind forces. Simpson is the leading name in the game and their most common products(or copies) are available at all big box stores
captaindiode
NC
Look like a good job. If termites are a concern, I would treat the lower 2 ft of the wall with boracare. It will penetrate the sheeting and the studs.
