Hi all, I have a 25x27 2.5 car garage from the mid-70's that was built on a flat slab with no curb of any kind, and built entirely of untreated wood. Due to rising soil levels and rotting sill plates (along with constant termite/carpenter ant infestations), I decided to cut the bottom 16in of the entire structure out and replace it with two courses of 8x8x16 concrete block on the load-bearing sidewalls, and 4x8x16 on front/rear nonstructural walls. The block walls are anchored to the slab with 1/2in rebar 6-8in deep in the slab every other block and all cores filled with acrylic-fortified sand mix for grout. The 2x8 sill plates are anchored into the stemwall with 1/2in anchors into the grout. This was all done DIY.
My questions are this: will this newly modified structure have the same wind-load resistance as before with the split wall? Will it resist stresses in a similar manner to before? Did I do anything wrong?
