Need Help with Cabinet Leveling Feet
LouG
Hi all ! Long time reader, not much of a poster here...
I'm just now starting a (to me) fairly major garage re-organization and just bought two Masterforce 36" tool cabinets. The cabinets will be sitting on a (pre-existing) 6" high, 36" deep concrete lip that is at the front of my garage, so I will not be using the casters that came with the cabinets. The screw size for attaching the casters is M8 x 25, but I'm having trouble finding a leveling foot that fits this size. I do not have the means of fabricating something to attach to the cabinet. I see others here using leveling feet on their HF tool cabinets but I don't see the HF cabinet owner's manual specifying the bolt size. I found this thread discussing the issue but the smallest size that McMaster sells is M10.
Can someone help with where I can find the correct size? If not, what would the standard (non-metric) size be ?
Dumber than lumber
If McMaster-Carr doesn't have it, you might be screwed (LOL).
Can you take the old casters and slice off the wheel portion?
L
LouG
Many thanks for all the quick replies....
Here is the Masterforce owner's manual. Please see page 5 for the caster install instructions where it discusses the bolt size.
Here is the McMaster leveling feet I'm looking at. Would these be a good bet to fit based on what little is known from the Masterforce manual ?
wssix99
Chicago, IL
You should abort your plan and take a look at other options. You can't just put a leveling foot in those holes. They aren't designed to take the weight. Your cabinet is designed for the weight to bear on the metal plate on the bottom of the unit. The nuts inside that the caster screws attach to are likely tack welded in lightly and would pop out if you loaded the cabinet on them. (With the caster screws tight and the casters on, those nuts are in compression against the bottom of the unit. Putting a leveling foot there would put them in tension from the bottom of the unit.)
Two options that I would consider:
- Cut some shims the same size as the caster base plate. Match the thickness to how ever high you would adjust the leveling foot to. Attach the shim blocks to the bottom with 4 M8 screws, just as you would the caster. (You would probably want to countersink some fluted head bolts in there so they recess inside the shim blocks.)
- See if you can modify the caster. Your caster is attached to its plate either by a pressed-in shaft or a threaded shaft and nut. (higher end) If you can remove the wheel portion of the caster from the plate, you might be able to bolt the plate (without the wheel attached) to your cabinet and then attach a static foot in the place of the shaft that held the wheel.
Viper98912
GA
Yea you can't just put a leveling foot in those M8 holes, the load is designed to push on the base, not the holes. I recommend fabricating your own plate that has a central hole for a standard leveling foot and then bolt that plate into the existing M8 holes.
Or use shims like others have said
Or use the casters and shim them individually
L
LouG
Thanks everyone. I may just go the shim route, either that or place the cabinets on a plywood base. I just don't want the cabinets sitting on the concrete floor themselves. The casters included with the cabinets are certainly well built for the task, but they add 5"-6" in height, and I'm trying to avoid that. I realize the Masterforce cabinets are more expensive than the US General boxes, but I still got the 11% Menards rebate and I love the blue finish.
kumquat
North of Montana aka Saskatchewan, Canada
bugnut
Central Ohio
If I were placing metal cabinets on the floor I would put cheap vinyl tile instead of wood as a breaker to keep the moisture away from the metal. Wood will gather moisture.
