| No. | Product name | Retail reference price | Release date |
| TDBRP6 | Precision ratchet screwdriver set 5 bits (10 types of tips) | ¥ 4,500 | August 2021 |
| TDBRPX7 | Precision ratchet screwdriver tool set 7 points | ¥ 4,500 | August 2021 |
I also used mine of stripped screw on my F150.I just recently bought those pliers from amazon as well. Actually came into use the other day......... changing out the pull switch on a ceiling fan. Some other pliers would have gotten the job done, but this was easier. Always some satisfaction when using a new tool for the first time and it makes the job easier, which is why I purchased it in the first place.
Bought and came in a couple of hours ago.Not quite sure what you mean, but the head has only one detent at the 180 degree (straight) position. There are no other stops, but the head is under tension — it doesn't move around when I shake the ratchet. I put a 17mm deep socket on it, and the head stays put at any position or orientation (in other words, if I tilt the ratchet down while the head is at an angle, the weight of the socket doesn't move it.)
The entire length is metal.How do the vessel ball grip interchangeable bit handles with the metal ferrule differ from the craftsman branded ones sold years ago that were all plastic?
Is it metal all the way down the entire length of where the bit is inside the driver, or is just a short section towards the end of the handle?
I forgot about the ratcheting ones, I mean the the ones with the double sided bit like on the right. The 220W3J1 is the same design as the craftsman ones, but the end is metal. I also just saw the 230w which is probably more in line with what I am looking for. I'm wondering if it's just like an inch of metal at the end with the rest being plastic, or if it is metal all the way to the end of the inside.The entire length is metal.
1/4" Drive Ratchets by ChrisCas aka Superautobacs, on Flickr
I thought the 230w was interesting because it was a strike able one, which makes me think it might be all metal internally and I was thinking of using it with long shank tapered driver bits, but the hex are only an inch or two long, which is why I was curious if the internals were all metal since I might as well just use my craftsman ones if the only section engaging the flats would be plastic as well.A ratcheting alternative to the 230W is the Anex 397. It's the one ratcheting driver I always keep in my tool
Chris, I wanted to say thank you for your YouTube video on the SEK Pro-Auto ratchets and their availability through Idaka. Using the the info from your video I was able to order all 3 of them and the total cost was just below $100 for all 3 delivered. Total time was around 2 weeks from when I ordered them until I received them at my home.I posted this in the Tiny Tools thread, but thought it deserves a spot here as well.
The smallest 1/4 drive ratchet I own to date is SEK's Pro-Auto 'Smart Head' ratchet Part # MHR-2 (COO is Taiwan). It is 72-tooth, has a built-in quick spinner on top, quick-release, and the back drag is really light.
So you're expecting more stuff then? Regardless, that's a nice haul!My box of tools from Japan finally arrived. Used a third party buying site and this has been a long painful process. They were suppose to combine orders from multiple vendors, but I was only able to receive items from 1 vendor. Koken zeal sockets in 1/4, 3/8 and 1/2 drive. KTC flare sockets and a bunch of items I cannot wait to try.
This order is finished. Surprised you noticed, tried to order only made in Japan items. I had a few things from other vendors that never shipped and after several Weeks without a status update. Finally cancelled the other orders. my notes to the third party asking for assistance were I guess ignored, or the seller never replied to them.So you're expecting more stuff then? Regardless, that's a nice haul!
FWIW, I think the only item that's not made in Japan is the SKll speeder T-handle.
Very nice! So would hat be about $300 for the set?The flex crowfeet are amazing this order fills in the other sizes I did not already own. They are thick and do not flex on stuck fittings, doubt I will break a Tone crowfoot socket. You can tell they are hand finished. Reasonable priced, the largest size 24mm (1/2 drive) is just under 25 dollars and smallest was 16 dollars. Not counting shipping and handling fees which added about 10% to the order. The flex crowfeet items were the main reason I placed the order, not available in the US at this price point.
I see you are new to the Forum GJ, welcome. KOKEN is what you want for sockets, do some searching on the forum here and you will get lots of feedback about KOKEN.Does anyone have any experience with Japanese made sockets? Are they better quality than the Chinese and Taiwanese stuff that we see? If so, are there any brands that are used by Japanese mechanics over other brands?
-Bryan
-Bryan
Maybe 285 plus shipping. So I have a little over 300. My first order was with Amazon.jp for the 6 piece set. The latest order better prices and lower shipping, but a headache. Amazon.jp asked 30ish + shipping for the larger sizes. Yen price x .0093 which worked at the time to convert to usd.Very nice! So would hat be about $300 for the set?
Nah, Ko-ken is **** ! i recommend he buys the full set of the latest Nepros Gold IP tools, nothing but the best.. lolI see you are new to the Forum GJ, welcome. KOKEN is what you want for sockets, do some searching on the forum here and you will get lots of feedback about KOKEN.
Now that's a good idea.... wish I had thought of it!does anyone know if vessel makes their impact screwdrivers in hex?
so do i am sick and tired of stripped shart collar bolts, rbrt had a 60 ish percentage success rate and concentional hex has no hopeNow that's a good idea.... wish I had thought of it!
thanks for the bottom picture i was seeing that pop up on amazon under the vessel name will have to see where i can find it under anex thanks so much
i tried rbrt hex on them its got like a 60% success rate i figured might try sticking and rbrt bit on the endyou mean megadora impacta (908 series)? no
MEGADORA|Screwdrivers|HAND TOOLS | PRODUCTS INFORMATION | VESSEL CO., INC
full range of information on product groups ranging from tightening tools such as drivers, bit sockets and air tools to anti-static products in the factoryvessel.co.jp
also, it sounds like a terrible idea to me. i'd use wera hex-plus keys or mac/proto RBRT hex sockets.
