I have seen a lot of questions on sub panels for remote shops. I just wanted to put all my information and see if my planning is correct. First the building will be a metal building.
Sorry if I’m asking the same question someone else may have. I have searched a lot a just want to make sure it is correct and not have to have the inspector come back several times and burn more money.
- The building is about 45 feet from the house.
- The plan is to run (3) #4 wires and (1) #6 for ground
- 2 Grounding rods that will be placed at least 6 feet apart.
- 60- or 70-amp breaker in the house to feed the sub-panel
- Currently it looks like it will (4) 110v breakers and (3) 220v breakers
- 3 - 20 amp for outlets (110v)
- 1 – 15 amp for lighting (110)
- 1 – 20 amp for air compressor (220v)
- 1 – 25 amp for mini spilt (220v)
- 1 – 30 amp for welder (220)
- Add a main breaker to the purchased panel
- Back feed a breaker with a hold down
- Return the panel and buy one with a main breaker
- Install a separate disconnect.
