question about automotive paint
handyman2020
Toronto
hello,
On this motorcycle exhaust, I got a scratch and i could see bare metal. so I bought " Rust-Oleum Specialty Automotive High Heat Paint in Flat Black, Spray Can for automotiv" as its "flat black" color.
https://www.rustoleum.com/product-c...alty-paints/high-heat?ls=248903&lc=Flat Black
I sanded the area to make it smooth with 400 grit and then I sprayed above Rustoleum product while exhaust was cold. After the spray dried it turned gray though the product says its flat black.
I even tried spraying while the exhaust was hot but same color gray is turning up
I also shook the can 1 minute prior to use.
Sprayed area turned more gray as compare to exhaust:-
^^^Sprayed area turned more gray as compare to exhaust. ^^^
I have no idea what to do, I do have a spray gun and compressor, if it takes to paint with spray gun to match and fix the scratch i will do it.
Please can someone guide me on
1 why Rustoleum is not turning flat black ?
2 how to match color as close as possible?
3 if not spray can then which color to buy or another brand high temperature spray can will do?
4 what is the actual color on this exhaust? how to find it?
This is the motorcycle exhaust.:-
^^^This is the motorcycle exhaust.^^^^
Thank you
ZRX61
Solar Blight Valley, SoCal
You'd probably have better luck with graphite stove polish, comes in a tube like toothpaste:
Is that factory paint on everything? It looks more graphite than flat black in the pic.
BillK
Beautiful Southern Maryland
If you spray it on a clean piece of metal what color is it ?? It should be black. It doesnt change color when it heats up. If its not black then the can might have been marked wrong.
I have always preferred VHT paint for headers and exhaust. They have been the go to paint for that use for many many years.
Not sure where it came from but I actually have a can of Rustoleum sitting on the shelf. Mine says 2000 degrees though. Its probably ancient. It does dry more towards a dark grey. I attached a picture below. The only VHT I have is Silver so I cant do a comparison.
H
handyman2020
Toronto
its still gray, i tried on 2 different metal first an iron plate shiny not rusty and second a small broken ipad ( back side aluminium frame silver dark gray color originally)
have you considered asking the motorcycle shop if they have a factory finish in a can?
not yet.
CraigStu
Blacksburg, Va
BBQ paint will work also. Like almost any basic color there are a lot of 'blacks'. And besides the color there are a lot of sheens. If the manufacturer doesn't offer paint I think you are going to have to buy several brands to see which is the best match.
