The autopro top box is rough, rusty inside, and needs some welding (rear of lid has split, hole bottom left front, spot weld gone on top front corners).
I don't think this will get away without 're paint.
The Gray top box is pretty good, but the front has had flames, a name, and various other stuff scratched in it. Alot of sticker fade too. Top is rough but I could live with it.
The mid box is just generally worn, and a little bent.
And the base cab is generally scratched, sticker damage, cement (which I will hopefully get off)
That last image is after a bit of a polish.
All the black marks are rust.
I'm in two minds to be honest. I'm not normally one for painting stuff unless it really needs it.
I'll probably try polishing it more first, but I really want to use the autopro top box and if that gets painted, the rest will need to be done to match!
